Set Persistent global variable using pymxs
stevkalinowski
stevkalinowski
I'm attempting to set persistent global variables in 3ds Max 2018 using pymxs.  Is this currently possible?  I have had a hard time finding any examples of this.
Here are some things that I have tried.  Each of these results in an "unsaveable file".  If I hit save after any of these Max crashes.
import pymxs
pymxsRt = pymxs.runtime
pymxsMp = getattr(pymxsRt, '%make_persistent')
global gTest
gTest = []
gTest.append('qwer')
gTest.append('asdf')
gTest.append('zxcv')
pymxsRt.persistents.append(gTest)
import pymxs
global gTest
gTest = []
pymxsMp( gTest, pymxsRt.persistents )
import pymxs
global gTest
gTest = []
pymxsMp( gTest )
I'm trying to avoid going between python and MaxScript since I have a PySide2 GUI and I have to pass data back and forth.
Also, are persistent global variables not advised for any reason?
denisT.MaxDoctor
first of all you have to make MXS global... not a Python global.
the only way to do it with pymxs i see:
rt = pymxs.runtime
rt.execute('global abcd')
after that use MXS struct "persistents":
rt.persistents.make('abcd')
rt.persistents.isPersistent('abcd')
rt.persistents.gather()
to set/get use "globalVars"
rt.globalVars.set('abcd', 12)
rt.globalVars.get('abcd')
to remove use "persistents" and "globalVars"
denisT.MaxDoctor
maybe with MaxPlus you can get direct access to "globals" and "persistents" sdk HashTable(s).. i never tried
denisT.MaxDoctor
at first glance it is impossible... i don't see any classes for that.
stevkalinowski
Hey hey!  How you doing man!
Thanks a bunch, this seems to work just fine.
