Callback when subobject is moved/rotated/scaled
Hello
I can't find in the documentation any way to register a callback related to a subobject being moved/rotated/scaled. In the class INodeEventCallback, there is a SubObjectSelectionChanged and a ControllerOtherEvents. The latter is related to the transform operations but at node level. I would like to listen to move/rotate/scale in one specific sub-object level in order to perform some other actions related to the selection.
Thanks in advance
denisT.MaxDoctor
try this snippet:
try
	newNodeEventCallback = undefined
	gc light:true
catch()
global newNodeEventCallback
global functions
struct FunctionStruct
	fn eventTestFn event handles =
		format "event:%\n" event
functions = FunctionStruct()
newNodeEventCallback = NodeEventCallback all:functions.eventTestFn
newNodeEventCallback.enabled = on
just evaluate it ... and you will see all Node Event Callbacks
#geometryChanged is specifically what you are looking for
Another way is to use
when geometry ... change
when topology ... change
we can talk about this option if Node Event Callbacks will not work for you for any reason
Thanks, very much appreciated your help.
