Announcements
Set bone keyframe tangents to linear with max script
DerSekki
DerSekki
I have following code:
rtb = $myRootBone
deleteKeys rtb
with animate on
    at time 0 rtb.pos = [0,0,0]
    at time (animationRange.end) rtb.pos = [0,-200,0]
    c = rtb.pos.controller
    if isProperty c #tangents do
        t = c.tangents
        for j = 1 to t.numKeys do
            t.setTangentType j #linear
            t.setWeight j 0.0
This script sets a starting and ending keyframe. This works. In the end, it should set the tangents to linear, but it doesn't. Any idea, what could be the problem?
denisT.MaxDoctor
Why should it work? As I know the Controller superclass doesn't have the #tangents property
You have at least three options to achieve what you want (linear in/out tangents):
1. Use linear controller:
delete objects
b = box isselected:on
b.pos.controller = linear_position()
with animate on
	at time animationrange.start
		b.pos = [0,0,0]
	at time ((animationrange.start + animationrange.end)/2)
		b.pos = [50,0,50]
	at time animationrange.end
		b.pos = [100,0,0]
2. Use default new key tangent type:
delete objects
def_in = BezierDefaultParams.inTangentType
def_out = BezierDefaultParams.outTangentType
BezierDefaultParams.inTangentType = #linear
BezierDefaultParams.outTangentType = #linear
--BezierDefaultParams.inTangentType = #flat
--BezierDefaultParams.outTangentType = #flat
with animate on
		b.pos = [0,0,0]
		b.pos = [50,0,50]
		b.pos = [100,0,0]
BezierDefaultParams.inTangentType = def_in
BezierDefaultParams.outTangentType = def_out
3. Set key's tangents:
delete objects
with animate on
		b.pos = [0,0,0]
		b.pos = [50,0,50]
		b.pos = [100,0,0]
p = b.pos.controller
for k=1 to 3 do
	for key in p[k].keys do
		key.intangenttype = #linear
		key.outtangenttype = #linear
Here is a homework:
Find another mxs built-in methods to do the same as in the solution #2
DerSekki
I used the first solution and it works like a charm. Unfortunately, im not a max scripter and i feel like documentation is close to non-existent (atleast, if im trying to google for it). It's probably just me and my searching skills.
Thank you. 🙂
