Announcements
Qt for Max SDK 2024
Qt for Max SDK 2024
tagopinath
Qt for Max SDK 2024
tagopinath
Hello everyone,
I am trying to update my plugins to Max 2024. I downloaded Max and SDK for the same.
When I try to compile a simple utility plugin, it shows error on Qt related files.
I downloaded Qt 5.15.1 from the below link.
https://github.com/autodesk-forks/qtbase/releases
On extracting, it gave some files. Inside folders I can see the header files - but not combined in a single folder.
Can anyone suggest how to use these files to work with SDK?
I can see qtbase.pro file in the main folder. I tried with CMake, but there is no CMakeLists file in that.
Gopinath.
istan
Needs to be downloaded from QT.
The github is supposed to hold all Autodesk changes, they made to the orginal QT sources.
But there are no offline installer packages anymore?!
Did AD probably add the QT libraries to their SDK or do we have to build them on our own?
Update: V5.15.2 can be downloaded from QT via Online Installer - the offline installer package is gone.
tagopinath
Hello All:
I am using the below.
1- Visual Studio 2019
2- 3ds Max 2024
3- QT 5.15.2
I am trying to compile new simple utility plugin but the below errors are getting, I have added the path of QT lib file with linker but I don't know why we are getting the below error.
Build started...
1>------ Build started: Project: maxProject7, Configuration: Release x64 ------
1> Creating library C:\Users\Santosh\source\repos\maxProject7\maxProject7\\obj\x64\Release\\maxProject7.lib and object C:\Users\Santosh\source\repos\maxProject7\maxProject7\\obj\x64\Release\\maxProject7.exp
1>maxProject7.obj : error LNK2019: unresolved external symbol "__declspec(dllimport) public: __cdecl QChar::QChar(struct QLatin1Char)" (__imp_??0QChar@@QEAA@UQLatin1Char@@@Z) referenced in function "private: void __cdecl maxProject7::DoSomething(void)" (?DoSomething@maxProject7@@AEAAXXZ)
1>maxProject7.obj : error LNK2019: unresolved external symbol "__declspec(dllimport) public: __cdecl QString::~QString(void)" (__imp_??1QString@@QEAA@XZ) referenced in function "private: void __cdecl maxProject7::DoSomething(void)" (?DoSomething@maxProject7@@AEAAXXZ)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "__declspec(dllimport) public: __cdecl QString::~QString(void)" (__imp_??1QString@@QEAA@XZ)
1>maxProject7.obj : error LNK2019: unresolved external symbol "__declspec(dllimport) public: class QString __cdecl QString::arg(int,int,int,class QChar)const " (__imp_?arg@QString@@QEBA?AV1@HHHVQChar@@@Z) referenced in function "private: void __cdecl maxProject7::DoSomething(void)" (?DoSomething@maxProject7@@AEAAXXZ)
1>maxProject7.obj : error LNK2019: unresolved external symbol "__declspec(dllimport) public: static class QString __cdecl QString::fromUtf8(char const *,int)" (__imp_?fromUtf8@QString@@SA?AV1@PEBDH@Z) referenced in function "public: void __cdecl Ui_PluginRollup::setupUi(class QWidget *)" (?setupUi@Ui_PluginRollup@@QEAAXPEAVQWidget@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "__declspec(dllimport) public: static class QString __cdecl QString::fromUtf8(char const *,int)" (__imp_?fromUtf8@QString@@SA?AV1@PEBDH@Z)
1>maxProject7.obj : error LNK2019: unresolved external symbol "__declspec(dllimport) private: static struct QTypedArrayData<unsigned short> * __cdecl QString::fromAscii_helper(char const *,int)" (__imp_?fromAscii_helper@QString@@CAPEAU?$QTypedArrayData@G@@PEBDH@Z) referenced in function "private: void __cdecl maxProject7::DoSomething(void)" (?DoSomething@maxProject7@@AEAAXXZ)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "__declspec(dllimport) private: static struct QTypedArrayData<unsigned short> * __cdecl QString::fromAscii_helper(char const *,int)" (__imp_?fromAscii_helper@QString@@CAPEAU?$QTypedArrayData@G@@PEBDH@Z)
1>maxProject7.obj : error LNK2019: unresolved external symbol "__declspec(dllimport) public: static void __cdecl QMetaObject::connectSlotsByName(class QObject *)" (__imp_?connectSlotsByName@QMetaObject@@SAXPEAVQObject@@@Z) referenced in function "public: void __cdecl Ui_PluginRollup::setupUi(class QWidget *)" (?setupUi@Ui_PluginRollup@@QEAAXPEAVQWidget@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "__declspec(dllimport) public: static void __cdecl QMetaObject::connectSlotsByName(class QObject *)" (__imp_?connectSlotsByName@QMetaObject@@SAXPEAVQObject@@@Z)
1>maxProject7.obj : error LNK2019: unresolved external symbol "__declspec(dllimport) public: __cdecl QMetaObject::Connection::~Connection(void)" (__imp_??1Connection@QMetaObject@@QEAA@XZ) referenced in function "public: virtual void __cdecl maxProject7::BeginEditParams(class Interface *,class IUtil *)" (?BeginEditParams@maxProject7@@UEAAXPEAVInterface@@PEAVIUtil@@@Z)
1>maxProject7.obj : error LNK2019: unresolved external symbol "__declspec(dllimport) public: __cdecl QObject::QObject(class QObject *)" (__imp_??0QObject@@QEAA@PEAV0@@Z) referenced in function "public: __cdecl maxProject7::maxProject7(void)" (??0maxProject7@@QEAA@XZ)
1>maxProject7.obj : error LNK2019: unresolved external symbol "__declspec(dllimport) public: virtual __cdecl QObject::~QObject(void)" (__imp_??1QObject@@UEAA@XZ) referenced in function "int `public: __cdecl maxProject7::maxProject7(void)'::`1'::dtor$1" (?dtor$1@?0???0maxProject7@@QEAA@XZ@4HA)
1>maxProject7.obj : error LNK2019: unresolved external symbol "__declspec(dllimport) public: class QString __cdecl QObject::objectName(void)const " (__imp_?objectName@QObject@@QEBA?AVQString@@XZ) referenced in function "public: void __cdecl Ui_PluginRollup::setupUi(class QWidget *)" (?setupUi@Ui_PluginRollup@@QEAAXPEAVQWidget@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "__declspec(dllimport) public: class QString __cdecl QObject::objectName(void)const " (__imp_?objectName@QObject@@QEBA?AVQString@@XZ)
1>maxProject7.obj : error LNK2019: unresolved external symbol "__declspec(dllimport) public: void __cdecl QObject::setObjectName(class QString const &)" (__imp_?setObjectName@QObject@@QEAAXAEBVQString@@@Z) referenced in function "public: void __cdecl Ui_PluginRollup::setupUi(class QWidget *)" (?setupUi@Ui_PluginRollup@@QEAAXPEAVQWidget@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "__declspec(dllimport) public: void __cdecl QObject::setObjectName(class QString const &)" (__imp_?setObjectName@QObject@@QEAAXAEBVQString@@@Z)
1>maxProject7.obj : error LNK2019: unresolved external symbol "__declspec(dllimport) private: static class QMetaObject::Connection __cdecl QObject::connectImpl(class QObject const *,void * *,class QObject const *,void * *,class QtPrivate::QSlotObjectBase *,enum Qt::ConnectionType,int const *,struct QMetaObject const *)" (__imp_?connectImpl@QObject@@CA?AVConnection@QMetaObject@@PEBV1@PEAPEAX01PEAVQSlotObjectBase@QtPrivate@@W4ConnectionType@Qt@@PEBHPEBU3@@Z) referenced in function "public: virtual void __cdecl maxProject7::BeginEditParams(class Interface *,class IUtil *)" (?BeginEditParams@maxProject7@@UEAAXPEAVInterface@@PEAVIUtil@@@Z)
1>maxProject7.obj : error LNK2019: unresolved external symbol "__declspec(dllimport) public: static class QString __cdecl QCoreApplication::translate(char const *,char const *,char const *,int)" (__imp_?translate@QCoreApplication@@SA?AVQString@@PEBD00H@Z) referenced in function "public: void __cdecl Ui_PluginRollup::setupUi(class QWidget *)" (?setupUi@Ui_PluginRollup@@QEAAXPEAVQWidget@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "__declspec(dllimport) public: static class QString __cdecl QCoreApplication::translate(char const *,char const *,char const *,int)" (__imp_?translate@QCoreApplication@@SA?AVQString@@PEBD00H@Z)
1>maxProject7.obj : error LNK2019: unresolved external symbol "__declspec(dllimport) public: __cdecl QWidget::QWidget(class QWidget *,class QFlags<enum Qt::WindowType>)" (__imp_??0QWidget@@QEAA@PEAV0@V?$QFlags@W4WindowType@Qt@@@@@Z) referenced in function "public: virtual void __cdecl maxProject7::BeginEditParams(class Interface *,class IUtil *)" (?BeginEditParams@maxProject7@@UEAAXPEAVInterface@@PEAVIUtil@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "__declspec(dllimport) public: __cdecl QWidget::QWidget(class QWidget *,class QFlags<enum Qt::WindowType>)" (__imp_??0QWidget@@QEAA@PEAV0@V?$QFlags@W4WindowType@Qt@@@@@Z)
1>maxProject7.obj : error LNK2019: unresolved external symbol "__declspec(dllimport) public: virtual __cdecl QWidget::~QWidget(void)" (__imp_??1QWidget@@UEAA@XZ) referenced in function "public: virtual void * __cdecl QWidget::`scalar deleting destructor'(unsigned int)" (??_GQWidget@@UEAAPEAXI@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "__declspec(dllimport) public: virtual __cdecl QWidget::~QWidget(void)" (__imp_??1QWidget@@UEAA@XZ)
1>maxProject7.obj : error LNK2019: unresolved external symbol "__declspec(dllimport) public: void __cdecl QWidget::setWindowTitle(class QString const &)" (__imp_?setWindowTitle@QWidget@@QEAAXAEBVQString@@@Z) referenced in function "public: void __cdecl Ui_PluginRollup::setupUi(class QWidget *)" (?setupUi@Ui_PluginRollup@@QEAAXPEAVQWidget@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "__declspec(dllimport) public: void __cdecl QWidget::setWindowTitle(class QString const &)" (__imp_?setWindowTitle@QWidget@@QEAAXAEBVQString@@@Z)
1>maxProject7.obj : error LNK2019: unresolved external symbol "__declspec(dllimport) public: void __cdecl QWidget::resize(class QSize const &)" (__imp_?resize@QWidget@@QEAAXAEBVQSize@@@Z) referenced in function "public: void __cdecl Ui_PluginRollup::setupUi(class QWidget *)" (?setupUi@Ui_PluginRollup@@QEAAXPEAVQWidget@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "__declspec(dllimport) public: void __cdecl QWidget::resize(class QSize const &)" (__imp_?resize@QWidget@@QEAAXAEBVQSize@@@Z)
1>maxProject7.obj : error LNK2019: unresolved external symbol "__declspec(dllimport) public: __cdecl QLabel::QLabel(class QWidget *,class QFlags<enum Qt::WindowType>)" (__imp_??0QLabel@@QEAA@PEAVQWidget@@V?$QFlags@W4WindowType@Qt@@@@@Z) referenced in function "public: void __cdecl Ui_PluginRollup::setupUi(class QWidget *)" (?setupUi@Ui_PluginRollup@@QEAAXPEAVQWidget@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "__declspec(dllimport) public: __cdecl QLabel::QLabel(class QWidget *,class QFlags<enum Qt::WindowType>)" (__imp_??0QLabel@@QEAA@PEAVQWidget@@V?$QFlags@W4WindowType@Qt@@@@@Z)
1>maxProject7.obj : error LNK2019: unresolved external symbol "__declspec(dllimport) public: virtual __cdecl QLabel::~QLabel(void)" (__imp_??1QLabel@@UEAA@XZ) referenced in function "public: virtual void * __cdecl QLabel::`scalar deleting destructor'(unsigned int)" (??_GQLabel@@UEAAPEAXI@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "__declspec(dllimport) public: virtual __cdecl QLabel::~QLabel(void)" (__imp_??1QLabel@@UEAA@XZ)
1>maxProject7.obj : error LNK2019: unresolved external symbol "__declspec(dllimport) public: void __cdecl QLabel::setAlignment(class QFlags<enum Qt::AlignmentFlag>)" (__imp_?setAlignment@QLabel@@QEAAXV?$QFlags@W4AlignmentFlag@Qt@@@@@Z) referenced in function "public: void __cdecl Ui_PluginRollup::setupUi(class QWidget *)" (?setupUi@Ui_PluginRollup@@QEAAXPEAVQWidget@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "__declspec(dllimport) public: void __cdecl QLabel::setAlignment(class QFlags<enum Qt::AlignmentFlag>)" (__imp_?setAlignment@QLabel@@QEAAXV?$QFlags@W4AlignmentFlag@Qt@@@@@Z)
1>maxProject7.obj : error LNK2019: unresolved external symbol "__declspec(dllimport) public: void __cdecl QLabel::setText(class QString const &)" (__imp_?setText@QLabel@@QEAAXAEBVQString@@@Z) referenced in function "public: void __cdecl Ui_PluginRollup::setupUi(class QWidget *)" (?setupUi@Ui_PluginRollup@@QEAAXPEAVQWidget@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "__declspec(dllimport) public: void __cdecl QLabel::setText(class QString const &)" (__imp_?setText@QLabel@@QEAAXAEBVQString@@@Z)
1>maxProject7.obj : error LNK2019: unresolved external symbol "__declspec(dllimport) public: void __cdecl QAbstractButton::setText(class QString const &)" (__imp_?setText@QAbstractButton@@QEAAXAEBVQString@@@Z) referenced in function "public: void __cdecl Ui_PluginRollup::setupUi(class QWidget *)" (?setupUi@Ui_PluginRollup@@QEAAXPEAVQWidget@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "__declspec(dllimport) public: void __cdecl QAbstractButton::setText(class QString const &)" (__imp_?setText@QAbstractButton@@QEAAXAEBVQString@@@Z)
1>maxProject7.obj : error LNK2019: unresolved external symbol "__declspec(dllimport) public: void __cdecl QAbstractButton::clicked(bool)" (__imp_?clicked@QAbstractButton@@QEAAX_N@Z) referenced in function "public: virtual void __cdecl maxProject7::BeginEditParams(class Interface *,class IUtil *)" (?BeginEditParams@maxProject7@@UEAAXPEAVInterface@@PEAVIUtil@@@Z)
1>maxProject7.obj : error LNK2019: unresolved external symbol "__declspec(dllimport) public: __cdecl QPushButton::QPushButton(class QWidget *)" (__imp_??0QPushButton@@QEAA@PEAVQWidget@@@Z) referenced in function "public: void __cdecl Ui_PluginRollup::setupUi(class QWidget *)" (?setupUi@Ui_PluginRollup@@QEAAXPEAVQWidget@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "__declspec(dllimport) public: __cdecl QPushButton::QPushButton(class QWidget *)" (__imp_??0QPushButton@@QEAA@PEAVQWidget@@@Z)
1>maxProject7.obj : error LNK2019: unresolved external symbol "__declspec(dllimport) public: virtual __cdecl QPushButton::~QPushButton(void)" (__imp_??1QPushButton@@UEAA@XZ) referenced in function "public: virtual void * __cdecl QPushButton::`scalar deleting destructor'(unsigned int)" (??_GQPushButton@@UEAAPEAXI@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "__declspec(dllimport) public: virtual __cdecl QPushButton::~QPushButton(void)" (__imp_??1QPushButton@@UEAA@XZ)
1>maxProject7.obj : error LNK2019: unresolved external symbol "__declspec(dllimport) public: void __cdecl QBoxLayout::addWidget(class QWidget *,int,class QFlags<enum Qt::AlignmentFlag>)" (__imp_?addWidget@QBoxLayout@@QEAAXPEAVQWidget@@HV?$QFlags@W4AlignmentFlag@Qt@@@@@Z) referenced in function "public: void __cdecl Ui_PluginRollup::setupUi(class QWidget *)" (?setupUi@Ui_PluginRollup@@QEAAXPEAVQWidget@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "__declspec(dllimport) public: void __cdecl QBoxLayout::addWidget(class QWidget *,int,class QFlags<enum Qt::AlignmentFlag>)" (__imp_?addWidget@QBoxLayout@@QEAAXPEAVQWidget@@HV?$QFlags@W4AlignmentFlag@Qt@@@@@Z)
1>maxProject7.obj : error LNK2019: unresolved external symbol "__declspec(dllimport) public: __cdecl QVBoxLayout::QVBoxLayout(class QWidget *)" (__imp_??0QVBoxLayout@@QEAA@PEAVQWidget@@@Z) referenced in function "public: void __cdecl Ui_PluginRollup::setupUi(class QWidget *)" (?setupUi@Ui_PluginRollup@@QEAAXPEAVQWidget@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "__declspec(dllimport) public: __cdecl QVBoxLayout::QVBoxLayout(class QWidget *)" (__imp_??0QVBoxLayout@@QEAA@PEAVQWidget@@@Z)
1>maxProject7.obj : error LNK2019: unresolved external symbol "__declspec(dllimport) public: virtual __cdecl QVBoxLayout::~QVBoxLayout(void)" (__imp_??1QVBoxLayout@@UEAA@XZ) referenced in function "public: virtual void * __cdecl QVBoxLayout::`scalar deleting destructor'(unsigned int)" (??_GQVBoxLayout@@UEAAPEAXI@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "__declspec(dllimport) public: virtual __cdecl QVBoxLayout::~QVBoxLayout(void)" (__imp_??1QVBoxLayout@@UEAA@XZ)
1>maxProject7.obj : error LNK2019: unresolved external symbol "__declspec(dllimport) public: int __cdecl QSpinBox::value(void)const " (__imp_?value@QSpinBox@@QEBAHXZ) referenced in function "private: void __cdecl maxProject7::DoSomething(void)" (?DoSomething@maxProject7@@AEAAXXZ)
1>maxProject7.obj : error LNK2019: unresolved external symbol "__declspec(dllimport) public: static enum QMessageBox::StandardButton __cdecl QMessageBox::information(class QWidget *,class QString const &,class QString const &,class QFlags<enum QMessageBox::StandardButton>,enum QMessageBox::StandardButton)" (__imp_?information@QMessageBox@@SA?AW4StandardButton@1@PEAVQWidget@@AEBVQString@@1V?$QFlags@W4StandardButton@QMessageBox@@@@W421@@Z) referenced in function "private: void __cdecl maxProject7::DoSomething(void)" (?DoSomething@maxProject7@@AEAAXXZ)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "__declspec(dllimport) public: static enum QMessageBox::StandardButton __cdecl QMessageBox::information(class QWidget *,class QString const &,class QString const &,class QFlags<enum QMessageBox::StandardButton>,enum QMessageBox::StandardButton)" (__imp_?information@QMessageBox@@SA?AW4StandardButton@1@PEAVQWidget@@AEBVQString@@1V?$QFlags@W4StandardButton@QMessageBox@@@@W421@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: __cdecl QString::~QString(void)" (??1QString@@QEAA@XZ)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "public: __cdecl QString::~QString(void)" (??1QString@@QEAA@XZ)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::actionEvent(class QActionEvent *)" (?actionEvent@QWidget@@MEAAXPEAVQActionEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::actionEvent(class QActionEvent *)" (?actionEvent@QWidget@@MEAAXPEAVQActionEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual void __cdecl QBoxLayout::addItem(class QLayoutItem *)" (?addItem@QBoxLayout@@UEAAXPEAVQLayoutItem@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "public: virtual void __cdecl QBoxLayout::addItem(class QLayoutItem *)" (?addItem@QBoxLayout@@UEAAXPEAVQLayoutItem@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QAbstractButton::changeEvent(class QEvent *)" (?changeEvent@QAbstractButton@@MEAAXPEAVQEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QAbstractButton::changeEvent(class QEvent *)" (?changeEvent@QAbstractButton@@MEAAXPEAVQEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QAbstractSpinBox::changeEvent(class QEvent *)" (?changeEvent@QAbstractSpinBox@@MEAAXPEAVQEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QAbstractSpinBox::changeEvent(class QEvent *)" (?changeEvent@QAbstractSpinBox@@MEAAXPEAVQEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QLabel::changeEvent(class QEvent *)" (?changeEvent@QLabel@@MEAAXPEAVQEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QLabel::changeEvent(class QEvent *)" (?changeEvent@QLabel@@MEAAXPEAVQEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::changeEvent(class QEvent *)" (?changeEvent@QWidget@@MEAAXPEAVQEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::changeEvent(class QEvent *)" (?changeEvent@QWidget@@MEAAXPEAVQEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QAbstractButton::checkStateSet(void)" (?checkStateSet@QAbstractButton@@MEAAXXZ)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QAbstractButton::checkStateSet(void)" (?checkStateSet@QAbstractButton@@MEAAXXZ)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QLayout::childEvent(class QChildEvent *)" (?childEvent@QLayout@@MEAAXPEAVQChildEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QLayout::childEvent(class QChildEvent *)" (?childEvent@QLayout@@MEAAXPEAVQChildEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QObject::childEvent(class QChildEvent *)" (?childEvent@QObject@@MEAAXPEAVQChildEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QObject::childEvent(class QChildEvent *)" (?childEvent@QObject@@MEAAXPEAVQChildEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual void __cdecl QAbstractSpinBox::clear(void)" (?clear@QAbstractSpinBox@@UEAAXXZ)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "public: virtual void __cdecl QAbstractSpinBox::clear(void)" (?clear@QAbstractSpinBox@@UEAAXXZ)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QAbstractSpinBox::closeEvent(class QCloseEvent *)" (?closeEvent@QAbstractSpinBox@@MEAAXPEAVQCloseEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QAbstractSpinBox::closeEvent(class QCloseEvent *)" (?closeEvent@QAbstractSpinBox@@MEAAXPEAVQCloseEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::closeEvent(class QCloseEvent *)" (?closeEvent@QWidget@@MEAAXPEAVQCloseEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::closeEvent(class QCloseEvent *)" (?closeEvent@QWidget@@MEAAXPEAVQCloseEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QObject::connectNotify(class QMetaMethod const &)" (?connectNotify@QObject@@MEAAXAEBVQMetaMethod@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QObject::connectNotify(class QMetaMethod const &)" (?connectNotify@QObject@@MEAAXAEBVQMetaMethod@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QLabel::contextMenuEvent(class QContextMenuEvent *)" (?contextMenuEvent@QLabel@@MEAAXPEAVQContextMenuEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QLabel::contextMenuEvent(class QContextMenuEvent *)" (?contextMenuEvent@QLabel@@MEAAXPEAVQContextMenuEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::contextMenuEvent(class QContextMenuEvent *)" (?contextMenuEvent@QWidget@@MEAAXPEAVQContextMenuEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::contextMenuEvent(class QContextMenuEvent *)" (?contextMenuEvent@QWidget@@MEAAXPEAVQContextMenuEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual class QFlags<enum QSizePolicy::ControlType> __cdecl QLayout::controlTypes(void)const " (?controlTypes@QLayout@@UEBA?AV?$QFlags@W4ControlType@QSizePolicy@@@@XZ)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "public: virtual class QFlags<enum QSizePolicy::ControlType> __cdecl QLayout::controlTypes(void)const " (?controlTypes@QLayout@@UEBA?AV?$QFlags@W4ControlType@QSizePolicy@@@@XZ)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual int __cdecl QBoxLayout::count(void)const " (?count@QBoxLayout@@UEBAHXZ)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "public: virtual int __cdecl QBoxLayout::count(void)const " (?count@QBoxLayout@@UEBAHXZ)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QObject::customEvent(class QEvent *)" (?customEvent@QObject@@MEAAXPEAVQEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QObject::customEvent(class QEvent *)" (?customEvent@QObject@@MEAAXPEAVQEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual int __cdecl QWidget::devType(void)const " (?devType@QWidget@@UEBAHXZ)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "public: virtual int __cdecl QWidget::devType(void)const " (?devType@QWidget@@UEBAHXZ)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QObject::disconnectNotify(class QMetaMethod const &)" (?disconnectNotify@QObject@@MEAAXAEBVQMetaMethod@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QObject::disconnectNotify(class QMetaMethod const &)" (?disconnectNotify@QObject@@MEAAXAEBVQMetaMethod@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::dragEnterEvent(class QDragEnterEvent *)" (?dragEnterEvent@QWidget@@MEAAXPEAVQDragEnterEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::dragEnterEvent(class QDragEnterEvent *)" (?dragEnterEvent@QWidget@@MEAAXPEAVQDragEnterEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::dragLeaveEvent(class QDragLeaveEvent *)" (?dragLeaveEvent@QWidget@@MEAAXPEAVQDragLeaveEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::dragLeaveEvent(class QDragLeaveEvent *)" (?dragLeaveEvent@QWidget@@MEAAXPEAVQDragLeaveEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::dragMoveEvent(class QDragMoveEvent *)" (?dragMoveEvent@QWidget@@MEAAXPEAVQDragMoveEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::dragMoveEvent(class QDragMoveEvent *)" (?dragMoveEvent@QWidget@@MEAAXPEAVQDragMoveEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::dropEvent(class QDropEvent *)" (?dropEvent@QWidget@@MEAAXPEAVQDropEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::dropEvent(class QDropEvent *)" (?dropEvent@QWidget@@MEAAXPEAVQDropEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::enterEvent(class QEvent *)" (?enterEvent@QWidget@@MEAAXPEAVQEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::enterEvent(class QEvent *)" (?enterEvent@QWidget@@MEAAXPEAVQEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual bool __cdecl QLabel::event(class QEvent *)" (?event@QLabel@@MEAA_NPEAVQEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual bool __cdecl QLabel::event(class QEvent *)" (?event@QLabel@@MEAA_NPEAVQEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual bool __cdecl QObject::event(class QEvent *)" (?event@QObject@@UEAA_NPEAVQEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "public: virtual bool __cdecl QObject::event(class QEvent *)" (?event@QObject@@UEAA_NPEAVQEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual bool __cdecl QPushButton::event(class QEvent *)" (?event@QPushButton@@MEAA_NPEAVQEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual bool __cdecl QPushButton::event(class QEvent *)" (?event@QPushButton@@MEAA_NPEAVQEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual bool __cdecl QSpinBox::event(class QEvent *)" (?event@QSpinBox@@MEAA_NPEAVQEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual bool __cdecl QSpinBox::event(class QEvent *)" (?event@QSpinBox@@MEAA_NPEAVQEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual bool __cdecl QWidget::event(class QEvent *)" (?event@QWidget@@MEAA_NPEAVQEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual bool __cdecl QWidget::event(class QEvent *)" (?event@QWidget@@MEAA_NPEAVQEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual bool __cdecl QObject::eventFilter(class QObject *,class QEvent *)" (?eventFilter@QObject@@UEAA_NPEAV1@PEAVQEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "public: virtual bool __cdecl QObject::eventFilter(class QObject *,class QEvent *)" (?eventFilter@QObject@@UEAA_NPEAV1@PEAVQEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual class QFlags<enum Qt::Orientation> __cdecl QBoxLayout::expandingDirections(void)const " (?expandingDirections@QBoxLayout@@UEBA?AV?$QFlags@W4Orientation@Qt@@@@XZ)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "public: virtual class QFlags<enum Qt::Orientation> __cdecl QBoxLayout::expandingDirections(void)const " (?expandingDirections@QBoxLayout@@UEBA?AV?$QFlags@W4Orientation@Qt@@@@XZ)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QSpinBox::fixup(class QString &)const " (?fixup@QSpinBox@@MEBAXAEAVQString@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QSpinBox::fixup(class QString &)const " (?fixup@QSpinBox@@MEBAXAEAVQString@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QAbstractSpinBox::focusInEvent(class QFocusEvent *)" (?focusInEvent@QAbstractSpinBox@@MEAAXPEAVQFocusEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QAbstractSpinBox::focusInEvent(class QFocusEvent *)" (?focusInEvent@QAbstractSpinBox@@MEAAXPEAVQFocusEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QLabel::focusInEvent(class QFocusEvent *)" (?focusInEvent@QLabel@@MEAAXPEAVQFocusEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QLabel::focusInEvent(class QFocusEvent *)" (?focusInEvent@QLabel@@MEAAXPEAVQFocusEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QPushButton::focusInEvent(class QFocusEvent *)" (?focusInEvent@QPushButton@@MEAAXPEAVQFocusEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QPushButton::focusInEvent(class QFocusEvent *)" (?focusInEvent@QPushButton@@MEAAXPEAVQFocusEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::focusInEvent(class QFocusEvent *)" (?focusInEvent@QWidget@@MEAAXPEAVQFocusEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::focusInEvent(class QFocusEvent *)" (?focusInEvent@QWidget@@MEAAXPEAVQFocusEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual bool __cdecl QLabel::focusNextPrevChild(bool)" (?focusNextPrevChild@QLabel@@MEAA_N_N@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual bool __cdecl QLabel::focusNextPrevChild(bool)" (?focusNextPrevChild@QLabel@@MEAA_N_N@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual bool __cdecl QWidget::focusNextPrevChild(bool)" (?focusNextPrevChild@QWidget@@MEAA_N_N@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual bool __cdecl QWidget::focusNextPrevChild(bool)" (?focusNextPrevChild@QWidget@@MEAA_N_N@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QAbstractSpinBox::focusOutEvent(class QFocusEvent *)" (?focusOutEvent@QAbstractSpinBox@@MEAAXPEAVQFocusEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QAbstractSpinBox::focusOutEvent(class QFocusEvent *)" (?focusOutEvent@QAbstractSpinBox@@MEAAXPEAVQFocusEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QLabel::focusOutEvent(class QFocusEvent *)" (?focusOutEvent@QLabel@@MEAAXPEAVQFocusEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QLabel::focusOutEvent(class QFocusEvent *)" (?focusOutEvent@QLabel@@MEAAXPEAVQFocusEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QPushButton::focusOutEvent(class QFocusEvent *)" (?focusOutEvent@QPushButton@@MEAAXPEAVQFocusEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QPushButton::focusOutEvent(class QFocusEvent *)" (?focusOutEvent@QPushButton@@MEAAXPEAVQFocusEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::focusOutEvent(class QFocusEvent *)" (?focusOutEvent@QWidget@@MEAAXPEAVQFocusEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::focusOutEvent(class QFocusEvent *)" (?focusOutEvent@QWidget@@MEAAXPEAVQFocusEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual class QRect __cdecl QLayout::geometry(void)const " (?geometry@QLayout@@UEBA?AVQRect@@XZ)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "public: virtual class QRect __cdecl QLayout::geometry(void)const " (?geometry@QLayout@@UEBA?AVQRect@@XZ)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual bool __cdecl QBoxLayout::hasHeightForWidth(void)const " (?hasHeightForWidth@QBoxLayout@@UEBA_NXZ)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "public: virtual bool __cdecl QBoxLayout::hasHeightForWidth(void)const " (?hasHeightForWidth@QBoxLayout@@UEBA_NXZ)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual bool __cdecl QWidget::hasHeightForWidth(void)const " (?hasHeightForWidth@QWidget@@UEBA_NXZ)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "public: virtual bool __cdecl QWidget::hasHeightForWidth(void)const " (?hasHeightForWidth@QWidget@@UEBA_NXZ)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual int __cdecl QBoxLayout::heightForWidth(int)const " (?heightForWidth@QBoxLayout@@UEBAHH@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "public: virtual int __cdecl QBoxLayout::heightForWidth(int)const " (?heightForWidth@QBoxLayout@@UEBAHH@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual int __cdecl QLabel::heightForWidth(int)const " (?heightForWidth@QLabel@@UEBAHH@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "public: virtual int __cdecl QLabel::heightForWidth(int)const " (?heightForWidth@QLabel@@UEBAHH@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual int __cdecl QWidget::heightForWidth(int)const " (?heightForWidth@QWidget@@UEBAHH@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "public: virtual int __cdecl QWidget::heightForWidth(int)const " (?heightForWidth@QWidget@@UEBAHH@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QAbstractSpinBox::hideEvent(class QHideEvent *)" (?hideEvent@QAbstractSpinBox@@MEAAXPEAVQHideEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QAbstractSpinBox::hideEvent(class QHideEvent *)" (?hideEvent@QAbstractSpinBox@@MEAAXPEAVQHideEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::hideEvent(class QHideEvent *)" (?hideEvent@QWidget@@MEAAXPEAVQHideEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::hideEvent(class QHideEvent *)" (?hideEvent@QWidget@@MEAAXPEAVQHideEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual bool __cdecl QPushButton::hitButton(class QPoint const &)const " (?hitButton@QPushButton@@MEBA_NAEBVQPoint@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual bool __cdecl QPushButton::hitButton(class QPoint const &)const " (?hitButton@QPushButton@@MEBA_NAEBVQPoint@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual int __cdecl QLayout::indexOf(class QWidget *)const " (?indexOf@QLayout@@UEBAHPEAVQWidget@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "public: virtual int __cdecl QLayout::indexOf(class QWidget *)const " (?indexOf@QLayout@@UEBAHPEAVQWidget@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::initPainter(class QPainter *)const " (?initPainter@QWidget@@MEBAXPEAVQPainter@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::initPainter(class QPainter *)const " (?initPainter@QWidget@@MEBAXPEAVQPainter@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::inputMethodEvent(class QInputMethodEvent *)" (?inputMethodEvent@QWidget@@MEAAXPEAVQInputMethodEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::inputMethodEvent(class QInputMethodEvent *)" (?inputMethodEvent@QWidget@@MEAAXPEAVQInputMethodEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual class QVariant __cdecl QAbstractSpinBox::inputMethodQuery(enum Qt::InputMethodQuery)const " (?inputMethodQuery@QAbstractSpinBox@@UEBA?AVQVariant@@W4InputMethodQuery@Qt@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "public: virtual class QVariant __cdecl QAbstractSpinBox::inputMethodQuery(enum Qt::InputMethodQuery)const " (?inputMethodQuery@QAbstractSpinBox@@UEBA?AVQVariant@@W4InputMethodQuery@Qt@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual class QVariant __cdecl QWidget::inputMethodQuery(enum Qt::InputMethodQuery)const " (?inputMethodQuery@QWidget@@UEBA?AVQVariant@@W4InputMethodQuery@Qt@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "public: virtual class QVariant __cdecl QWidget::inputMethodQuery(enum Qt::InputMethodQuery)const " (?inputMethodQuery@QWidget@@UEBA?AVQVariant@@W4InputMethodQuery@Qt@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual void __cdecl QBoxLayout::invalidate(void)" (?invalidate@QBoxLayout@@UEAAXXZ)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "public: virtual void __cdecl QBoxLayout::invalidate(void)" (?invalidate@QBoxLayout@@UEAAXXZ)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual bool __cdecl QLayout::isEmpty(void)const " (?isEmpty@QLayout@@UEBA_NXZ)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "public: virtual bool __cdecl QLayout::isEmpty(void)const " (?isEmpty@QLayout@@UEBA_NXZ)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual class QLayoutItem * __cdecl QBoxLayout::itemAt(int)const " (?itemAt@QBoxLayout@@UEBAPEAVQLayoutItem@@H@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "public: virtual class QLayoutItem * __cdecl QBoxLayout::itemAt(int)const " (?itemAt@QBoxLayout@@UEBAPEAVQLayoutItem@@H@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QLabel::keyPressEvent(class QKeyEvent *)" (?keyPressEvent@QLabel@@MEAAXPEAVQKeyEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QLabel::keyPressEvent(class QKeyEvent *)" (?keyPressEvent@QLabel@@MEAAXPEAVQKeyEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QPushButton::keyPressEvent(class QKeyEvent *)" (?keyPressEvent@QPushButton@@MEAAXPEAVQKeyEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QPushButton::keyPressEvent(class QKeyEvent *)" (?keyPressEvent@QPushButton@@MEAAXPEAVQKeyEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::keyPressEvent(class QKeyEvent *)" (?keyPressEvent@QWidget@@MEAAXPEAVQKeyEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::keyPressEvent(class QKeyEvent *)" (?keyPressEvent@QWidget@@MEAAXPEAVQKeyEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QAbstractButton::keyReleaseEvent(class QKeyEvent *)" (?keyReleaseEvent@QAbstractButton@@MEAAXPEAVQKeyEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QAbstractButton::keyReleaseEvent(class QKeyEvent *)" (?keyReleaseEvent@QAbstractButton@@MEAAXPEAVQKeyEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QAbstractSpinBox::keyReleaseEvent(class QKeyEvent *)" (?keyReleaseEvent@QAbstractSpinBox@@MEAAXPEAVQKeyEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QAbstractSpinBox::keyReleaseEvent(class QKeyEvent *)" (?keyReleaseEvent@QAbstractSpinBox@@MEAAXPEAVQKeyEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::keyReleaseEvent(class QKeyEvent *)" (?keyReleaseEvent@QWidget@@MEAAXPEAVQKeyEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::keyReleaseEvent(class QKeyEvent *)" (?keyReleaseEvent@QWidget@@MEAAXPEAVQKeyEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual class QLayout * __cdecl QLayout::layout(void)" (?layout@QLayout@@UEAAPEAV1@XZ)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "public: virtual class QLayout * __cdecl QLayout::layout(void)" (?layout@QLayout@@UEAAPEAV1@XZ)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::leaveEvent(class QEvent *)" (?leaveEvent@QWidget@@MEAAXPEAVQEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::leaveEvent(class QEvent *)" (?leaveEvent@QWidget@@MEAAXPEAVQEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual class QSize __cdecl QBoxLayout::maximumSize(void)const " (?maximumSize@QBoxLayout@@UEBA?AVQSize@@XZ)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "public: virtual class QSize __cdecl QBoxLayout::maximumSize(void)const " (?maximumSize@QBoxLayout@@UEBA?AVQSize@@XZ)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual struct QMetaObject const * __cdecl QLabel::metaObject(void)const " (?metaObject@QLabel@@UEBAPEBUQMetaObject@@XZ)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "public: virtual struct QMetaObject const * __cdecl QLabel::metaObject(void)const " (?metaObject@QLabel@@UEBAPEBUQMetaObject@@XZ)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual struct QMetaObject const * __cdecl QObject::metaObject(void)const " (?metaObject@QObject@@UEBAPEBUQMetaObject@@XZ)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual struct QMetaObject const * __cdecl QPushButton::metaObject(void)const " (?metaObject@QPushButton@@UEBAPEBUQMetaObject@@XZ)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "public: virtual struct QMetaObject const * __cdecl QPushButton::metaObject(void)const " (?metaObject@QPushButton@@UEBAPEBUQMetaObject@@XZ)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual struct QMetaObject const * __cdecl QVBoxLayout::metaObject(void)const " (?metaObject@QVBoxLayout@@UEBAPEBUQMetaObject@@XZ)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "public: virtual struct QMetaObject const * __cdecl QVBoxLayout::metaObject(void)const " (?metaObject@QVBoxLayout@@UEBAPEBUQMetaObject@@XZ)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual struct QMetaObject const * __cdecl QWidget::metaObject(void)const " (?metaObject@QWidget@@UEBAPEBUQMetaObject@@XZ)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "public: virtual struct QMetaObject const * __cdecl QWidget::metaObject(void)const " (?metaObject@QWidget@@UEBAPEBUQMetaObject@@XZ)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual int __cdecl QWidget::metric(enum QPaintDevice::PaintDeviceMetric)const " (?metric@QWidget@@MEBAHW4PaintDeviceMetric@QPaintDevice@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual int __cdecl QWidget::metric(enum QPaintDevice::PaintDeviceMetric)const " (?metric@QWidget@@MEBAHW4PaintDeviceMetric@QPaintDevice@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual int __cdecl QBoxLayout::minimumHeightForWidth(int)const " (?minimumHeightForWidth@QBoxLayout@@UEBAHH@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "public: virtual int __cdecl QBoxLayout::minimumHeightForWidth(int)const " (?minimumHeightForWidth@QBoxLayout@@UEBAHH@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual class QSize __cdecl QBoxLayout::minimumSize(void)const " (?minimumSize@QBoxLayout@@UEBA?AVQSize@@XZ)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "public: virtual class QSize __cdecl QBoxLayout::minimumSize(void)const " (?minimumSize@QBoxLayout@@UEBA?AVQSize@@XZ)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual class QSize __cdecl QLabel::minimumSizeHint(void)const " (?minimumSizeHint@QLabel@@UEBA?AVQSize@@XZ)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "public: virtual class QSize __cdecl QLabel::minimumSizeHint(void)const " (?minimumSizeHint@QLabel@@UEBA?AVQSize@@XZ)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual class QSize __cdecl QPushButton::minimumSizeHint(void)const " (?minimumSizeHint@QPushButton@@UEBA?AVQSize@@XZ)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "public: virtual class QSize __cdecl QPushButton::minimumSizeHint(void)const " (?minimumSizeHint@QPushButton@@UEBA?AVQSize@@XZ)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual class QSize __cdecl QWidget::minimumSizeHint(void)const " (?minimumSizeHint@QWidget@@UEBA?AVQSize@@XZ)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "public: virtual class QSize __cdecl QWidget::minimumSizeHint(void)const " (?minimumSizeHint@QWidget@@UEBA?AVQSize@@XZ)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::mouseDoubleClickEvent(class QMouseEvent *)" (?mouseDoubleClickEvent@QWidget@@MEAAXPEAVQMouseEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::mouseDoubleClickEvent(class QMouseEvent *)" (?mouseDoubleClickEvent@QWidget@@MEAAXPEAVQMouseEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QAbstractButton::mouseMoveEvent(class QMouseEvent *)" (?mouseMoveEvent@QAbstractButton@@MEAAXPEAVQMouseEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QAbstractButton::mouseMoveEvent(class QMouseEvent *)" (?mouseMoveEvent@QAbstractButton@@MEAAXPEAVQMouseEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QLabel::mouseMoveEvent(class QMouseEvent *)" (?mouseMoveEvent@QLabel@@MEAAXPEAVQMouseEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QLabel::mouseMoveEvent(class QMouseEvent *)" (?mouseMoveEvent@QLabel@@MEAAXPEAVQMouseEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::mouseMoveEvent(class QMouseEvent *)" (?mouseMoveEvent@QWidget@@MEAAXPEAVQMouseEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::mouseMoveEvent(class QMouseEvent *)" (?mouseMoveEvent@QWidget@@MEAAXPEAVQMouseEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QAbstractButton::mousePressEvent(class QMouseEvent *)" (?mousePressEvent@QAbstractButton@@MEAAXPEAVQMouseEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QAbstractButton::mousePressEvent(class QMouseEvent *)" (?mousePressEvent@QAbstractButton@@MEAAXPEAVQMouseEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QLabel::mousePressEvent(class QMouseEvent *)" (?mousePressEvent@QLabel@@MEAAXPEAVQMouseEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QLabel::mousePressEvent(class QMouseEvent *)" (?mousePressEvent@QLabel@@MEAAXPEAVQMouseEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::mousePressEvent(class QMouseEvent *)" (?mousePressEvent@QWidget@@MEAAXPEAVQMouseEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::mousePressEvent(class QMouseEvent *)" (?mousePressEvent@QWidget@@MEAAXPEAVQMouseEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QAbstractButton::mouseReleaseEvent(class QMouseEvent *)" (?mouseReleaseEvent@QAbstractButton@@MEAAXPEAVQMouseEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QAbstractButton::mouseReleaseEvent(class QMouseEvent *)" (?mouseReleaseEvent@QAbstractButton@@MEAAXPEAVQMouseEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QLabel::mouseReleaseEvent(class QMouseEvent *)" (?mouseReleaseEvent@QLabel@@MEAAXPEAVQMouseEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QLabel::mouseReleaseEvent(class QMouseEvent *)" (?mouseReleaseEvent@QLabel@@MEAAXPEAVQMouseEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::mouseReleaseEvent(class QMouseEvent *)" (?mouseReleaseEvent@QWidget@@MEAAXPEAVQMouseEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::mouseReleaseEvent(class QMouseEvent *)" (?mouseReleaseEvent@QWidget@@MEAAXPEAVQMouseEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::moveEvent(class QMoveEvent *)" (?moveEvent@QWidget@@MEAAXPEAVQMoveEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::moveEvent(class QMoveEvent *)" (?moveEvent@QWidget@@MEAAXPEAVQMoveEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual bool __cdecl QWidget::nativeEvent(class QByteArray const &,void *,long *)" (?nativeEvent@QWidget@@MEAA_NAEBVQByteArray@@PEAXPEAJ@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual bool __cdecl QWidget::nativeEvent(class QByteArray const &,void *,long *)" (?nativeEvent@QWidget@@MEAA_NAEBVQByteArray@@PEAXPEAJ@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QAbstractButton::nextCheckState(void)" (?nextCheckState@QAbstractButton@@MEAAXXZ)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QAbstractButton::nextCheckState(void)" (?nextCheckState@QAbstractButton@@MEAAXXZ)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual class QPaintEngine * __cdecl QWidget::paintEngine(void)const " (?paintEngine@QWidget@@UEBAPEAVQPaintEngine@@XZ)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "public: virtual class QPaintEngine * __cdecl QWidget::paintEngine(void)const " (?paintEngine@QWidget@@UEBAPEAVQPaintEngine@@XZ)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QLabel::paintEvent(class QPaintEvent *)" (?paintEvent@QLabel@@MEAAXPEAVQPaintEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QLabel::paintEvent(class QPaintEvent *)" (?paintEvent@QLabel@@MEAAXPEAVQPaintEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QPushButton::paintEvent(class QPaintEvent *)" (?paintEvent@QPushButton@@MEAAXPEAVQPaintEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QPushButton::paintEvent(class QPaintEvent *)" (?paintEvent@QPushButton@@MEAAXPEAVQPaintEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::paintEvent(class QPaintEvent *)" (?paintEvent@QWidget@@MEAAXPEAVQPaintEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::paintEvent(class QPaintEvent *)" (?paintEvent@QWidget@@MEAAXPEAVQPaintEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual int __cdecl QLabel::qt_metacall(enum QMetaObject::Call,int,void * *)" (?qt_metacall@QLabel@@UEAAHW4Call@QMetaObject@@HPEAPEAX@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "public: virtual int __cdecl QLabel::qt_metacall(enum QMetaObject::Call,int,void * *)" (?qt_metacall@QLabel@@UEAAHW4Call@QMetaObject@@HPEAPEAX@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual int __cdecl QObject::qt_metacall(enum QMetaObject::Call,int,void * *)" (?qt_metacall@QObject@@UEAAHW4Call@QMetaObject@@HPEAPEAX@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual int __cdecl QPushButton::qt_metacall(enum QMetaObject::Call,int,void * *)" (?qt_metacall@QPushButton@@UEAAHW4Call@QMetaObject@@HPEAPEAX@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "public: virtual int __cdecl QPushButton::qt_metacall(enum QMetaObject::Call,int,void * *)" (?qt_metacall@QPushButton@@UEAAHW4Call@QMetaObject@@HPEAPEAX@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual int __cdecl QVBoxLayout::qt_metacall(enum QMetaObject::Call,int,void * *)" (?qt_metacall@QVBoxLayout@@UEAAHW4Call@QMetaObject@@HPEAPEAX@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "public: virtual int __cdecl QVBoxLayout::qt_metacall(enum QMetaObject::Call,int,void * *)" (?qt_metacall@QVBoxLayout@@UEAAHW4Call@QMetaObject@@HPEAPEAX@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual int __cdecl QWidget::qt_metacall(enum QMetaObject::Call,int,void * *)" (?qt_metacall@QWidget@@UEAAHW4Call@QMetaObject@@HPEAPEAX@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "public: virtual int __cdecl QWidget::qt_metacall(enum QMetaObject::Call,int,void * *)" (?qt_metacall@QWidget@@UEAAHW4Call@QMetaObject@@HPEAPEAX@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual void * __cdecl QLabel::qt_metacast(char const *)" (?qt_metacast@QLabel@@UEAAPEAXPEBD@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "public: virtual void * __cdecl QLabel::qt_metacast(char const *)" (?qt_metacast@QLabel@@UEAAPEAXPEBD@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual void * __cdecl QObject::qt_metacast(char const *)" (?qt_metacast@QObject@@UEAAPEAXPEBD@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual void * __cdecl QPushButton::qt_metacast(char const *)" (?qt_metacast@QPushButton@@UEAAPEAXPEBD@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "public: virtual void * __cdecl QPushButton::qt_metacast(char const *)" (?qt_metacast@QPushButton@@UEAAPEAXPEBD@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual void * __cdecl QVBoxLayout::qt_metacast(char const *)" (?qt_metacast@QVBoxLayout@@UEAAPEAXPEBD@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "public: virtual void * __cdecl QVBoxLayout::qt_metacast(char const *)" (?qt_metacast@QVBoxLayout@@UEAAPEAXPEBD@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual void * __cdecl QWidget::qt_metacast(char const *)" (?qt_metacast@QWidget@@UEAAPEAXPEBD@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "public: virtual void * __cdecl QWidget::qt_metacast(char const *)" (?qt_metacast@QWidget@@UEAAPEAXPEBD@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual class QPaintDevice * __cdecl QWidget::redirected(class QPoint *)const " (?redirected@QWidget@@MEBAPEAVQPaintDevice@@PEAVQPoint@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual class QPaintDevice * __cdecl QWidget::redirected(class QPoint *)const " (?redirected@QWidget@@MEBAPEAVQPaintDevice@@PEAVQPoint@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QAbstractSpinBox::resizeEvent(class QResizeEvent *)" (?resizeEvent@QAbstractSpinBox@@MEAAXPEAVQResizeEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QAbstractSpinBox::resizeEvent(class QResizeEvent *)" (?resizeEvent@QAbstractSpinBox@@MEAAXPEAVQResizeEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::resizeEvent(class QResizeEvent *)" (?resizeEvent@QWidget@@MEAAXPEAVQResizeEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::resizeEvent(class QResizeEvent *)" (?resizeEvent@QWidget@@MEAAXPEAVQResizeEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual void __cdecl QBoxLayout::setGeometry(class QRect const &)" (?setGeometry@QBoxLayout@@UEAAXAEBVQRect@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "public: virtual void __cdecl QBoxLayout::setGeometry(class QRect const &)" (?setGeometry@QBoxLayout@@UEAAXAEBVQRect@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual void __cdecl QWidget::setVisible(bool)" (?setVisible@QWidget@@UEAAX_N@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "public: virtual void __cdecl QWidget::setVisible(bool)" (?setVisible@QWidget@@UEAAX_N@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual class QPainter * __cdecl QWidget::sharedPainter(void)const " (?sharedPainter@QWidget@@MEBAPEAVQPainter@@XZ)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual class QPainter * __cdecl QWidget::sharedPainter(void)const " (?sharedPainter@QWidget@@MEBAPEAVQPainter@@XZ)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QAbstractSpinBox::showEvent(class QShowEvent *)" (?showEvent@QAbstractSpinBox@@MEAAXPEAVQShowEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QAbstractSpinBox::showEvent(class QShowEvent *)" (?showEvent@QAbstractSpinBox@@MEAAXPEAVQShowEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::showEvent(class QShowEvent *)" (?showEvent@QWidget@@MEAAXPEAVQShowEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::showEvent(class QShowEvent *)" (?showEvent@QWidget@@MEAAXPEAVQShowEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual class QSize __cdecl QBoxLayout::sizeHint(void)const " (?sizeHint@QBoxLayout@@UEBA?AVQSize@@XZ)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "public: virtual class QSize __cdecl QBoxLayout::sizeHint(void)const " (?sizeHint@QBoxLayout@@UEBA?AVQSize@@XZ)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual class QSize __cdecl QLabel::sizeHint(void)const " (?sizeHint@QLabel@@UEBA?AVQSize@@XZ)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "public: virtual class QSize __cdecl QLabel::sizeHint(void)const " (?sizeHint@QLabel@@UEBA?AVQSize@@XZ)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual class QSize __cdecl QPushButton::sizeHint(void)const " (?sizeHint@QPushButton@@UEBA?AVQSize@@XZ)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "public: virtual class QSize __cdecl QPushButton::sizeHint(void)const " (?sizeHint@QPushButton@@UEBA?AVQSize@@XZ)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual class QSize __cdecl QWidget::sizeHint(void)const " (?sizeHint@QWidget@@UEBA?AVQSize@@XZ)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "public: virtual class QSize __cdecl QWidget::sizeHint(void)const " (?sizeHint@QWidget@@UEBA?AVQSize@@XZ)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual class QSpacerItem * __cdecl QLayoutItem::spacerItem(void)" (?spacerItem@QLayoutItem@@UEAAPEAVQSpacerItem@@XZ)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "public: virtual class QSpacerItem * __cdecl QLayoutItem::spacerItem(void)" (?spacerItem@QLayoutItem@@UEAAPEAVQSpacerItem@@XZ)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual class QFlags<enum QAbstractSpinBox::StepEnabledFlag> __cdecl QAbstractSpinBox::stepEnabled(void)const " (?stepEnabled@QAbstractSpinBox@@MEBA?AV?$QFlags@W4StepEnabledFlag@QAbstractSpinBox@@@@XZ)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual class QFlags<enum QAbstractSpinBox::StepEnabledFlag> __cdecl QAbstractSpinBox::stepEnabled(void)const " (?stepEnabled@QAbstractSpinBox@@MEBA?AV?$QFlags@W4StepEnabledFlag@QAbstractSpinBox@@@@XZ)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::tabletEvent(class QTabletEvent *)" (?tabletEvent@QWidget@@MEAAXPEAVQTabletEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::tabletEvent(class QTabletEvent *)" (?tabletEvent@QWidget@@MEAAXPEAVQTabletEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual class QLayoutItem * __cdecl QBoxLayout::takeAt(int)" (?takeAt@QBoxLayout@@UEAAPEAVQLayoutItem@@H@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "public: virtual class QLayoutItem * __cdecl QBoxLayout::takeAt(int)" (?takeAt@QBoxLayout@@UEAAPEAVQLayoutItem@@H@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual class QString __cdecl QSpinBox::textFromValue(int)const " (?textFromValue@QSpinBox@@MEBA?AVQString@@H@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual class QString __cdecl QSpinBox::textFromValue(int)const " (?textFromValue@QSpinBox@@MEBA?AVQString@@H@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QAbstractButton::timerEvent(class QTimerEvent *)" (?timerEvent@QAbstractButton@@MEAAXPEAVQTimerEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QAbstractButton::timerEvent(class QTimerEvent *)" (?timerEvent@QAbstractButton@@MEAAXPEAVQTimerEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QObject::timerEvent(class QTimerEvent *)" (?timerEvent@QObject@@MEAAXPEAVQTimerEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QObject::timerEvent(class QTimerEvent *)" (?timerEvent@QObject@@MEAAXPEAVQTimerEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QAbstractSpinBox::wheelEvent(class QWheelEvent *)" (?wheelEvent@QAbstractSpinBox@@MEAAXPEAVQWheelEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QAbstractSpinBox::wheelEvent(class QWheelEvent *)" (?wheelEvent@QAbstractSpinBox@@MEAAXPEAVQWheelEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::wheelEvent(class QWheelEvent *)" (?wheelEvent@QWidget@@MEAAXPEAVQWheelEvent@@@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "protected: virtual void __cdecl QWidget::wheelEvent(class QWheelEvent *)" (?wheelEvent@QWidget@@MEAAXPEAVQWheelEvent@@@Z)
1>maxProject7.obj : error LNK2001: unresolved external symbol "public: virtual class QWidget * __cdecl QLayoutItem::widget(void)" (?widget@QLayoutItem@@UEAAPEAVQWidget@@XZ)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "public: virtual class QWidget * __cdecl QLayoutItem::widget(void)" (?widget@QLayoutItem@@UEAAPEAVQWidget@@XZ)
1>maxProject7.obj : error LNK2019: unresolved external symbol "__declspec(dllimport) public: static struct QMetaObject const QAbstractButton::staticMetaObject" (__imp_?staticMetaObject@QAbstractButton@@2UQMetaObject@@B) referenced in function "public: virtual void __cdecl maxProject7::BeginEditParams(class Interface *,class IUtil *)" (?BeginEditParams@maxProject7@@UEAAXPEAVInterface@@PEAVIUtil@@@Z)
1>moc_QtPluginRollup.obj : error LNK2019: unresolved external symbol "__declspec(dllimport) public: static struct QMetaObject const QWidget::staticMetaObject" (__imp_?staticMetaObject@QWidget@@2UQMetaObject@@B) referenced in function "void __cdecl `dynamic initializer for 'public: static struct QMetaObject const QtPluginRollup::staticMetaObject''(void)" (??__E?staticMetaObject@QtPluginRollup@@2UQMetaObject@@B@@YAXXZ)
1>moc_QtPluginRollup.obj : error LNK2019: unresolved external symbol "__declspec(dllimport) public: struct QMetaObject * __cdecl QObjectData::dynamicMetaObject(void)const " (__imp_?dynamicMetaObject@QObjectData@@QEBAPEAUQMetaObject@@XZ) referenced in function "public: virtual struct QMetaObject const * __cdecl QtPluginRollup::metaObject(void)const " (?metaObject@QtPluginRollup@@UEBAPEBUQMetaObject@@XZ)
1>moc_QtPluginRollup.obj : error LNK2019: unresolved external symbol "__declspec(dllimport) public: virtual void * __cdecl QWidget::qt_metacast(char const *)" (__imp_?qt_metacast@QWidget@@UEAAPEAXPEBD@Z) referenced in function "public: virtual void * __cdecl QtPluginRollup::qt_metacast(char const *)" (?qt_metacast@QtPluginRollup@@UEAAPEAXPEBD@Z)
1> Hint on symbols that are defined and could potentially match:
1> "__declspec(dllimport) public: virtual void * __cdecl MaxSDK::QmaxSpinBox::qt_metacast(char const *)" (__imp_?qt_metacast@QmaxSpinBox@MaxSDK@@UEAAPEAXPEBD@Z)
1>moc_QtPluginRollup.obj : error LNK2019: unresolved external symbol "__declspec(dllimport) public: virtual int __cdecl QWidget::qt_metacall(enum QMetaObject::Call,int,void * *)" (__imp_?qt_metacall@QWidget@@UEAAHW4Call@QMetaObject@@HPEAPEAX@Z) referenced in function "public: virtual int __cdecl QtPluginRollup::qt_metacall(enum QMetaObject::Call,int,void * *)" (?qt_metacall@QtPluginRollup@@UEAAHW4Call@QMetaObject@@HPEAPEAX@Z)
1> "__declspec(dllimport) public: virtual int __cdecl MaxSDK::QmaxSpinBox::qt_metacall(enum QMetaObject::Call,int,void * *)" (__imp_?qt_metacall@QmaxSpinBox@MaxSDK@@UEAAHW4Call@QMetaObject@@HPEAPEAX@Z)
1>QtPluginRollup.obj : error LNK2001: unresolved external symbol "public: virtual __cdecl QWidget::~QWidget(void)" (??1QWidget@@UEAA@XZ)
1>C:\Qt\5.15.2\msvc2019\lib\Qt5Core.lib : warning LNK4272: library machine type 'x86' conflicts with target machine type 'x64'
1>C:\Qt\5.15.2\msvc2019\lib\Qt5Cored.lib : warning LNK4272: library machine type 'x86' conflicts with target machine type 'x64'
1>C:\Qt\5.15.2\msvc2019\lib\Qt5Gui.lib : warning LNK4272: library machine type 'x86' conflicts with target machine type 'x64'
1>C:\Qt\5.15.2\msvc2019\lib\Qt5Guid.lib : warning LNK4272: library machine type 'x86' conflicts with target machine type 'x64'
1>C:\Qt\5.15.2\msvc2019\lib\Qt5Widgets.lib : warning LNK4272: library machine type 'x86' conflicts with target machine type 'x64'
1>C:\Qt\5.15.2\msvc2019\lib\Qt5Widgetsd.lib : warning LNK4272: library machine type 'x86' conflicts with target machine type 'x64'
1>C:\Program Files\Autodesk\3ds Max 2024\stdplugs\maxProject7.dlu : fatal error LNK1120: 166 unresolved externals
1>Done building project "maxProject7.vcxproj" -- FAILED.
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
Chandroday Singh
tagopinath
Dear All:
While creating new simple utility plugin when we are doing uncheck this option "Use QT UI" (refer attached below) and click on finish button after that plugin is getting compiled successfully (as per the below), so please let us know when this option "Use QT UI" is checked then why utility plugin is not getting compiled (as we posted above) , whether this option is linked with QT Creator IDE or we can run our plugin without checking this option?
Build started...
1>------ Build started: Project: maxProject8, Configuration: Release x64 ------
1>maxProject8.cpp
1>DllEntry.cpp
1>C:\Users\Santosh\source\repos\maxProject8\maxProject8\DllEntry.cpp(78): TODO: Perform initialization here.
1>C:\Users\Santosh\source\repos\maxProject8\maxProject8\DllEntry.cpp(87): TODO: Perform un-initialization here.
1>C:\Users\Santosh\source\repos\maxProject8\maxProject8\maxProject8.cpp(122): TODO: React to the user interface commands. A utility plug-in is controlled by the user from here.
1> Creating library C:\Users\Santosh\source\repos\maxProject8\maxProject8\\obj\x64\Release\\maxProject8.lib and object C:\Users\Santosh\source\repos\maxProject8\maxProject8\\obj\x64\Release\\maxProject8.exp
1>maxProject8.vcxproj -> C:\Program Files\Autodesk\3ds Max 2024\stdplugs\maxProject8.dlu
1>C:\Users\Santosh\source\repos\maxProject8\maxProject8\obj\x64\Release\maxProject8.dlu.muiLanguage neutral file successfully created at "C:\Users\Santosh\source\repos\maxProject8\maxProject8\obj\x64\Release\maxProject8.dlu.ln".
1>MUI file successfully created at "C:\Users\Santosh\source\repos\maxProject8\maxProject8\obj\x64\Release\maxProject8.dlu.mui".
========== Build: 1 succeeded, 0 failed, 0 up-to-date, 0 skipped ==========
Chandroday Singh
istan
I don't know anything about the 3dsmax-wizard and Max2024 but the following error comes up, when a required library file (in your case QT) was not specified (path + name) for the linker.
error LNK2019: unresolved external symbol "__declspec(dllimport) public: __cdecl QChar::QChar(struct QLatin1Char)
The relevant information is in the error message. I usually set up all of my projects by hand and do not trust wizards 😉
