semi-dynamic parameter default in scripted plugin
12:20 AM
Does anyone know if there is a way to change the default value of a parameter before a scripted plugin object is created?
Essentially I want to count the number of a certain type of object in the scene and make the parameter default to that number plus one in the rollout.
ie if we had one box in the scene, it's 'testParam' would be set to one. With 20 boxes in the scene, if we created a new box it's 'testParam' would be 21.
I can set this in the 'tool create' section, but I want it to be visible in the rollout and changable before the object is created.
As an aside, does anyone know why the parameter defaults are used in the initial rollout rather than the rollout defaults?
Testing codes as follows:
The line:
is where I'm having the problem. Ideally it would be as simple as
however that doesn't work. Neither does (my implementation of) an execute line, as mentioned here
I'm trying the execute as follows;
or;
Any help much appreciated
plugin helper test
category:"test"
classID:#(0x3d3f8c7a, 0x470fa329)
extends: exposetm
initialRollupState: 0x00000007
version: 1
fn GetNodeCount =
nodeCount =0
for i in helpers do
if (hasProperty i "pTestParam") then
nodeCount += 1
nodeCount
local lNodeCount = GetNodeCount()
parameters qmotionParam rollout: testRollout
pTestParam type:#integer animatable:false ui:uTestParam default:25
tool create
on mousePoint clickno do
if (clickno == 1) then
nodeTM.position = worldPoint
delegate.useParent = false
delegate.box = true
delegate.cross = false
on mouseMove clickno do
if (clickno == 2) then
else
(#stop)
rollout testRollout "Testing"
Spinner uTestParam "Test:" type:#integer range:
The line:
pTestParam type:#integer animatable:false ui:uTestParam default:lNodeCount
execute "pTestParam type:#integer animatable:false ui:uTestParam default:" + lNodeCount as string
or;
execute "parameters qmotionParam rollout: testRollout\n (pTestParam type:#integer animatable:false ui:uTestParam default:" + lNodeCount as string+")"
