semi-dynamic parameter default in scripted plugin
Does anyone know if there is a way to change the default value of a parameter before a scripted plugin object is created?
Essentially I want to count the number of a certain type of object in the scene and make the parameter default to that number plus one in the rollout.
ie if we had one box in the scene, it's 'testParam' would be set to one. With 20 boxes in the scene, if we created a new box it's 'testParam' would be 21.
I can set this in the 'tool create' section, but I want it to be visible in the rollout and changable before the object is created.
As an aside, does anyone know why the parameter defaults are used in the initial rollout rather than the rollout defaults?
Testing codes as follows:
plugin helper test
category:"test"
classID:#(0x3d3f8c7a, 0x470fa329)
extends: exposetm
initialRollupState: 0x00000007
version: 1
fn GetNodeCount =
nodeCount =0
for i in helpers do
if (hasProperty i "pTestParam") then
nodeCount += 1
nodeCount
local lNodeCount = GetNodeCount()
parameters qmotionParam rollout: testRollout
pTestParam type:#integer animatable:false ui:uTestParam default:25
tool create
on mousePoint clickno do
if (clickno == 1) then
nodeTM.position = worldPoint
delegate.useParent = false
delegate.box = true
delegate.cross = false
on mouseMove clickno do
if (clickno == 2) then
else
(#stop)
rollout testRollout "Testing"
Spinner uTestParam "Test:" type:#integer range:
The line:
is where I'm having the problem. Ideally it would be as simple as
pTestParam type:#integer animatable:false ui:uTestParam default:lNodeCount
however that doesn't work. Neither does (my implementation of) an execute line, as mentioned here
I'm trying the execute as follows;
execute "pTestParam type:#integer animatable:false ui:uTestParam default:" + lNodeCount as string
or;
execute "parameters qmotionParam rollout: testRollout\n (pTestParam type:#integer animatable:false ui:uTestParam default:" + lNodeCount as string+")"
Any help much appreciated
I really don't know what I'm doing, but I stumbled on a bit of a hack...
Change:
pTestParam type:#integer animatable:false ui:uTestParam default:999999
And:
Nowhere near the right way to do it, but if you're in a jam...
MP
Aha! Thanks for your reply Melting Point, unfortunately I need to keep the maximum value of the parameter defined. I was thinking perhaps I could redefine the maximum on creation which directed me to solution.
The secret is that any 'on <parameter> set' clause is called when the rollout is created. I'm not really sure if it's actually when the rollout is created, but it's definitely called after you press the 'create object' button and before you create the object.
on pTestParam set val do if (lCreated == false) then
pTestParam = GetNodeCount()
Of course the problem is that it would then count nodes whenever you tried to set it manually afterward, hence the lCreated test. If we set lCreated to true when the object is created, then that clause isn't called after that point. I'm sure it will bite me down the track, but works for now.
Thanks for your input again MeltingPoint 🙂
Full working code as follows;
plugin helper test
category:"test"
extends: exposetm
version: 1
fn GetNodeCount =
/* Count the number of nodes in the scene and add one */
nodeCount =1
/* loop through all helpers in the scene and count then number with the "pTestParam" parameter */
for i in helpers do
nodeCount += 1
nodeCount
/* variable to tell if object has been created */
local lCreated = false
/* standard parameter declaration, connected to spinner below, default 66 would usually
be default value before creation */
pTestParam type:#integer animatable:false ui:uTestParam default:66
/* test if parameter has been set and the object has not been created */
/* set the parameter to the number of nodes in the scene including the current */
tool create
/* create object in the mouse position */
/* the object has now been created */
lCreated = true
/* cosmetic changes to the node left in from previous code */
delegate.box = true
/* move object as long as mouse is down */
else
(#stop)
/* standard spinner, integer from 0 to 100 default 50. Default here is not effective */
Edit: Added comments to code to help other newbies (used /* comments as they show up better in the browser)
Actually that doesn't work. Moved the lCreated flag = true to inside the 'on set' clause so it only runs once.
plugin helper test
category:"test"
extends: exposetm
version: 1
fn GetNodeCount =
nodeCount =1
for i in helpers do
nodeCount += 1
nodeCount
/* only run this sesction once */
lCreated = true
tool create
delegate.box = true
else
(#stop)
Nice work around. I just can't shake the feeling that there's a 'proper' way to do it. But when something works... don't fix it 🙂
Just a note in case anyone else uses this code.
The local variable lCreated needs to be changed to a parameter instead. It needs to be saved and loaded with the plugin nodes, otherwise all the nodeCounts will change to the number of nodes in the scene whenever a file containing the plugin is loaded.
MeltingPoint, I'm starting to believe that with maxScript there is never a 'proper' way of doing it 😉
