Selection Pivot
Selection Pivot
blakestone
Selection Pivot
blakestone
I have spent the last few hours looking through the help file and can not find anywhere how to obtain the location of the selected vertices, edges, faces etc. pivot.
It clearly shows it in the following 2 locations (see attachment) however I'm not sure how to get these values?
Technical 3D Graphic Artist
Autodesk 3dsMax 2015 - Service Pack 4
Steve_Curley
Good question. Can be done for an Editable Mesh - averageSelVertCenter < node > - but like you I can't find an equivalent for an Editable Poly. Probably one of those things which is blindingly obvious - once you've been told how to do it 😉
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
blakestone
Nice find, however a quick test and it does not appear to give the expected results (see attachment).
Steve_Curley
Hmmm, I created a Plane, converted to Editable Mesh, selected 4 vertices and entered "averageSelVertCenter $" into the listener. Same values as were being displayed in the 3 spinners at the bottom of the Max window.
I just tried
 b = Box pos: (averageSelVertCenter $)
and it created a box whose pivot point agreed with the aforementioned "center" of the 4 selected vertices. "$" MUST be an Editable Mesh - that function returns undefined if it's an Editable Poly.
Still need to find an equivalent method of obtaining that information from an Editable Poly though 😞
Max 2016 (SP1/EXT1)
