Select CAT layer via MaxScript?
peter.spence
peter.spence
I'm trying to wire 2 parameters via MaxScript. However, I have a few layers in the CAT Layer Manager. It seems that only the layer that is selected is then visible to the scripted parameters. So I'm trying to find a way to select the CAT Layer Manager layer in the script too.
Here's an example using a layer named Animation (with a Master object wiring to a Slave CAT object):
paramWire.connect $Master.rotation.controller[#X_Rotation] $Slave.transform.controller.LayerTrans.controller.Animation.controller.Rotation.controller[#Z_Rotation] "X_Rotation"
Everything works unless I have previously selected another layer in the CAT Layer Manager.
Any ideas?
Kind regards,
Peter Spence
Putty Studios
Characters & Visual Effects
www.PuttyStudios.com
ads_royje
Hi @peter.spence ,
to be able to select a CAT layer via Maxscript, it can be done by selecting it by its index ID.
For instance, with CAT parent selected
$<CAT parent>.numLayers
will return the numbers of layers.
$.<CAT parent>.selectedLayer
will return the index of the current selected layer.
$.<CAT parent>.selectedLayer=2
will select the layer 2
In documentation:
http://help.autodesk.com/view/3DSMAX/2020/ENU/?guid=GUID-A2663EFC-8DBE-4F18-9327-C1AFF6019BA1
I hope this can help,
peter.spence
That's great, thanks!
I'd been trying to do all sorts of MaxScript madness and completely over-complicating myself. Your help brought me back down to sanity, and solved the problem.
Kind regards,
Peter Spence
Putty Studios
ads_royje
Awesome to read 🙂
Thank you for your feedback!
