[SDK] SimpleObject2 - Display() or PrepareDisplay() are never called...
mateusz_s
mateusz_s
I tried to draw something in viewport or render custom Mesh, but I noticed that Display() or PrepareDisplay() methods are never called (I put a DebugPrint info inside to track them).. What is wrong? I am making SimpleObject2 plugin from PluginWizard.. any ideas?
istan
mateusz_s
Yes I read it, I know that using Display() is deprecated, and should not work when Nitrous is used.. although it works in Modifier plugin, and is still being used in SDK example codes and help files (very confusing)
But the Nitrous functions PrepareDisplay() and UpdatePerNode() are also not called.. its weird..
mateusz_s
Yes, I finally figure out..
The problem was in overriding this virtual method:
BaseInterface* myObject::GetInterface(Interface_ID iid)
but I was following Max SDK help file:
http://help.autodesk.com/cloudhelp/2017/ENU/Max-SDK/files/GUID-A7262BEC-A063-4E70-A1D9-7971DBF2E883.... I
I should not ovrride it and everything works. Overriding this virtual method:
unsigned long myObject::GetObjectDisplayRequirement() const
by returning for ex: MaxSDK::Graphics::ObjectDisplayRequireLegacyDisplayMode; will call Display() method
returning 0 will call PrepareDisplay() and UpdatePerNodeItems()
Now drawing meshes and lines in viewport works great..
