SDK animation export problem (rotation).
Hi, I'm trying to export rotation keyframes of an object and I have a little problem.
Everything works fine if the rotation degree is less than 270. If the rotation degree is more than 270 -my object strangely "flips"  and then finishes his rotation.
Here's the sample rotation data from my export:
The object is rotating from 0 (frame 0) to 360 (frame 100) degrees.
The problem appears in +/- 64 frame.
Frame: 0: [1.000000,-0.000000,0.000000,-0.000000]
Frame: 4: [0.999892,-0.000000,0.014677,-0.000000]
Frame: 8: [0.998370,-0.000000,0.057071,-0.000000]
Frame: 12: [0.992215,-0.000000,0.124535,-0.000000]
Frame: 16: [0.976861,-0.000000,0.213873,-0.000000]
Frame: 20: [0.947098,-0.000000,0.320944,-0.000000]
Frame: 24: [0.897817,-0.000000,0.440368,-0.000000]
Frame: 28: [0.824785,-0.000000,0.565446,-0.000000]
Frame: 32: [0.725380,-0.000000,0.688349,-0.000000]
Frame: 36: [0.599194,-0.000000,0.800604,-0.000000]
Frame: 40: [0.448383,-0.000000,0.893841,-0.000000]
Frame: 44: [0.277687,-0.000000,0.960671,-0.000000]
Frame: 48: [0.094058,-0.000000,0.995567,-0.000000]
Frame: 52: [-0.094058,-0.000000,0.995567,-0.000000]
Frame: 56: [-0.277688,-0.000000,0.960671,-0.000000]
Frame: 60: [-0.448383,-0.000000,0.893841,-0.000000]
Frame: 64: [0.599194,-0.000000,-0.800604,-0.000000]
Frame: 68: [0.725380,-0.000000,-0.688348,-0.000000]
Frame: 72: [0.824785,-0.000000,-0.565446,-0.000000]
Frame: 76: [0.897817,-0.000000,-0.440368,-0.000000]
Frame: 80: [0.947098,-0.000000,-0.320943,-0.000000]
Frame: 84: [0.976861,-0.000000,-0.213873,-0.000000]
Frame: 88: [0.992215,-0.000000,-0.124535,-0.000000]
Frame: 92: [0.998370,-0.000000,-0.057070,-0.000000]
Frame: 96: [0.999892,-0.000000,-0.014677,-0.000000]
Frame: 100: [1.000000,-0.000000,0.000000,-0.000000]
Can anyone have an idea how to solve the problem?
Regards, Larry
istan
you should also explain how you get these lines.. how you "export" what exactly?
Here's my code for keyframe export:
Matrix3 tm;
AffineParts ap;
TimeValue t;
for (t=start; t<=end; t+=delta) {
	tm = node->GetNodeTM(t) * Inverse(node->GetParentTM(t));
	decomp_affine(tm, &ap);
        Quat q = ap.q ;
(and here save quaternion values x,y,z,w)
istan
take a look at a 3x3 matrix.. cannot store multiple rotations..
Hmmm, so how to solve my problem? How to get keyframe data for more than 360 degrees rotations?
istan
you could export the animation keys.. if you just want to export, why you don't use the igame interface? http://docs.autodesk.com/3DSMAX/16/ENU/3ds-Max-SDK-Programmer-Guide/index.html?url=cpp_ref/class_i_g...
