Scripted Shape Plug-ins; trying to write a plugin for this shape...
I'm trying to write a plugin in maxscript to get a shape as shown.
The idea is to click points A, B en C, to define the basic shape, after that the radii could be adjusted in the modifier panel.
I don't know where to begin; when I look at the Scripted Shape Plug-ins entry in the MAXScript reference it says: "Scripted Shape plug-ins can only extend existing Shape plug-ins."
Do i have to start with a "donut" object and modify that?
MLB
You might be better off writing a standard-type script that creates the shape rather than trying to create a plug-in. Personally, I've never had any luck with a scripted Shape plug-in. You can probably do some tricks to keep the data with it so the script could modify it parametrically, which would give you most of the benefits of a plug-in.
I know how to do the math, but i don't know how to get it into a nice 'package'.
Does anyone know of a script I can use as a basis?
MLB
I'm with Stokes on this...you would probably have to extend the basic line shape and make the
shape you want. Another option could be a helper using gw calls, but that is even more prone to
hair-pulling and flipping off your monitor.
If I had to pump something out, I would reverse engineer the spline, and make a function that
did all the steps required to recreate the spline modified by input settings. The tool/"plugin"
would just manage the variables that affect the spline.
paulneale
I don't believe that scripted shapes work very well at all. I don't remember what the issues where
but I found that it wasn't possible to use them.
Paul Neale
http://paulneale.com
Paul Neale
gplourde
The issue since max 7 was that it crashed max when you opened a scene with a scripted shape in it. Creation worked fine. It work fin in 2009 now but I have no idea when this was fixed. Fairly sure it crash in max 9 also.
I'd create the shapes in a custom tool, and add a custom attribute to the new node to tweak the radius after creation.
This may be the issue: (in the attachment)
It didn't work for 'delegate' or 'this' ( Max 9 ).
If someone knows a way to add splines to a shape plug-in please let me know!
mspen inbox dot com
-Matt
