Script wish: removing multi/sub material assignment on mesh that only uses one material
Haider_of_Sweden
Message 1 of 9
Haider_of_Sweden
Could someone please help me with a Maxscript, that assigns only that one material from a multi-sub material that is used on a mesh, based on its ID?
Background:
I got a mesh with multiple IDs
Naturally, you need a multi/sub material for each ID
I have a script that detaches the mesh based on their ID
So far, each mesh still has a multi/sub material assigned. I might want to reorder the IDs, or attach and do a new Match Material IDs to Material. There might be other cases you need this to be cleaned up.
Accepted solutions (3)
Replies (8)
Message 2 of 9
denisT.MaxDoctor
mapped fn assignSingleSubMaterial node =
	fn getMeshMaterialIds node =
		ids = #{}
		mesh = node.mesh
		for f=1 to mesh.numfaces do append ids (getFaceMatID mesh f)
		ids
	res = false
	if iskindof node GeometryClass and iskindof node.mat MultiMaterial do
		ids = getMeshMaterialIds node
		if ids != undefined and ids.numberset == 1 do
			id = (ids as array)[1]
			if id <= node.mat.numsubs do
				node.mat = getsubmtl node.mat id
				res = true
	res
assignSingleSubMaterial objects
-- or
--assignSingleSubMaterial selection
-- or
--assignSingleSubMaterial geometry
Message 3 of 9
Haider_of_Sweden
A bit late, but thanks, @denisT.MaxDoctor !
I wanted to add a Material modifier, and set it to 1.
addModifier $ (Materialmodifier materialid:1)
I think there might be a better way.
The purpose is that once this object has one single material, I would want to reset the IDs as well.
How can it be done?
Message 4 of 9
denisT.MaxDoctor
if we are working with an editable_mesh or an editable_poly nodes, we can set face ids directly. Also we can do something special for patches and splines. But for other geometry cases, the only way is to use the Material modifier.
so the function could be something like this:
fn setNodeMaterialID node id:1 =
	if iskindof node Editable_Mesh then
		for f=1 to node.numfaces do setfacematid node f id
		true
	else if iskindof node Editable_Poly then
		polyop.setfacematid node #all id
		true
	else
		--addmodifier node (Materialmodifier id:1)
		false
Message 5 of 9
Haider_of_Sweden
		true
		true
	else
		false
Even though I have an editable Poly, I had to go for the addmodifier option.
That was not how it should work, or? Or is it me using the function wrong?
Message 6 of 9
denisT.MaxDoctor
you are using selection in your code.
selection is not a single node, it's a collection of nodes. that's why my function is not working. We can make the function mapped so that it works for a set of objects, or you have to call selection[1] which means the first selected node
Message 7 of 9
Haider_of_Sweden
I was going to use it together with your first assignSingleSubMaterial anyway, so I tried with mapped and selection and it works.
How did you intend it to be used?
Also. a strange behavior (for me at least, illiterate in MXS as I am) I encountered during my tests, is when I wrote setNodeMaterialID objects
I selected only the split objects, not the single objects with multi-sub-materials.
Then I ran both assignSingleSubMaterial objects and setNodeMaterialID objects (note objects), this happened
does Objects mean ALL objects in the scene?
Message 8 of 9
denisT.MaxDoctor
run all definitions...
and do example code (commented part) line by line:
fn test_setMatID node:selection[1] rangeID:[1,64] =
	for f in (node.faces as bitarray) do polyop.setfacematid node f (random rangeID[1] rangeID[2])
fn collectByMatID node =
	ids = #()
		id = polyop.getfacematid node f
		if ids[id] == undefined do ids[id] = #{}
		append ids[id] f
	ids
fn collectMatIDs node =
	ids = #{}
	for f in (node.faces as bitarray) do append ids (polyop.getfacematid node f)
	ids
fn detachByID node parent:undefined = if iskindof node Editable_Poly do
	ids = collectMatIDs node
	num = 0
	for id in ids do
		node.selectByMaterial id
		if (polyop.detachfaces node node.selectedfaces delete:on asnode:on name:("id_" + id as string)) do
			objects[objects.count].parent = parent
			num += 1
	num
mapped fn setPolyMaterialID node id = if iskindof node Editable_Poly do
	true
mapped fn assignSingleSubMaterial node resetID = if iskindof node Editable_Poly do
	res = false
	if iskindof node.mat MultiMaterial do
		ids = #{}
		for f=1 to node.numfaces do append ids (polyop.getFaceMatID node f)
		if ids.numberset == 1 do
				node.mat = node.mat[id]
				res = true
		if resetID != unsupplied do setPolyMaterialID node resetID
	res
fn hsv_to_rgb hsv =
	rgb = black -- it might be any color
	rgb.v = hsv.z
	rgb.s = hsv.y
	rgb.h = hsv.x
	rgb
fn test_makeMultiMaterial name: numsubs: =
	mat = Multimaterial name:name numsubs:numsubs
	num = mat.numsubs
	step = 255.0/num
	for k=1 to num do
		mat[k].name = "IDx" + k as string
		mat[k].diffuse = hsv_to_rgb [(k - 0.5)*step, 255,255]
	mat
mapped fn test_pushPoly node offset =
	v = polyop.getfacenormal node 1
	node.transform *= transmatrix (v * offset)
delete objects
gc()
bx = converttopoly (box name:"BX") -- this is a poly box with 6 mat ids
ids = collectMatIDs bx
meditmaterials[1] = bx.mat = test_makeMultiMaterial numsubs:ids.numberset
d = dummy name:#master transform:bx.transform
detachByID bx parent:d
test_pushPoly d.children 10
assignSingleSubMaterial d.children 1
format "name:% >> mat:%\n" bx.name bx.mat
for c in d.children do format "name:% >> ids:% mat:% (%)\n" c.name (collectMatIDs c) c.mat c.mat.diffuse
Message 9 of 9
denisT.MaxDoctor
I've fixed couple bugs in the previous code
