Script to connect aligned vertexes of a spline ?
Message 1 of 9
Hello Guys,
I need a little help with script creation and I thought maybe anyone could help.
I want to create a script that's capable of creating multiple splines (or connecting multiple verts of a spline) in a given axis of aligned vertexes.
For example, in the image bellow, I need it to close the selected spline to form 3 rectangles. I thought maybe I could make this happen by telling the script to connect the vertexes that are aligned in Y axis in this exemple.
And this is what I got so far, I cant tell Maxscript to enter in the sub_object and enter the connect modifier. But I have no clue how to do the rest
Could anyone help ?
It would be very handy to me and maybe to others too 🙂
Replies (8)
Message 2 of 9
leeminardi
Posting a few examples of a before and after spline(s) would make it more clear what you want to do with the script.
lee.minardi
Message 3 of 9
Yeah sure,
So, this is a very simple example of what I'm trying to do :
Connect the aligned vertices in Y axis, in this example, to create multiple rectangles with it.
Since I work with architecture modelling I do this all the time to create the walls bellow a window or a door.
Maybe another way to do it could be creating multiple shapes in Y axis to form the rectangles and then weld the vertices later on (but it seems a bit more complicated, idk).
Message 4 of 9
Alfred.DeFlaminis
Hello @Anonymous and welcome to the community,
This script is a bit beyond my capabilities, I think the best path forward is for me to move this thread to the programming forum to see if anyone there has some suggestions for you.  I will do so now!  Thanks.
Best Regards,
Message 5 of 9
denisT.MaxDoctor
if you run this function with two selected splines of a splineshape, it will connect them...
fn connectTwoSplines sp: =
	if sp == unsupplied do sp = selection[1]
	if iskindof sp SplineShape do
		ss = getsplineselection sp
		if ss.count == 2 and not isclosed sp ss[1] and not isclosed sp ss[2] do
			converttosplineshape sp
			k0 = getknotpoint sp ss[1] 1
			s = 1
			n = numknots sp ss[2]
			k1 = getknotpoint sp ss[2] s
			k2 = getknotpoint sp ss[2] n
			setKnotSelection sp ss[1] #(1)
			k = addnewspline sp
			if distance k0 k1 < distance k0 k2 then (swap s n) else (k1 = k2)
			addknot sp k #corner #line k0
			addknot sp k #corner #line k1
			weldSpline sp 0.0001
			n = numknots sp ss[1]
			setInVec sp ss[1] 1 (getknotpoint sp ss[1] 1)
			setOutVec sp ss[1] n (getknotpoint sp ss[1] n)
			close sp ss[1]
			setsplineselection sp #(ss[1])
connectTwoSplines()
but it's not how i would do it...
Message 6 of 9
denisT.MaxDoctor
Here is a cleaner version. But as I said it's not how it should be done. The solution is very specific and might work in very narrow area:
	if iskindof sp SplineShape or iskindof sp Line do
		if ss.count == 2 do
			s1 = ss[1]
			s2 = ss[2]
			if not isclosed sp s1 and not isclosed sp s2 do
				s1_0 = getknotpoint sp s1 1
				s1_1 = getknotpoint sp s1 (numknots sp s1)
				s2_0 = getknotpoint sp s2 1
				s2_1 = getknotpoint sp s2 (numknots sp s2)
				pp = if (distance s1_0 s2_0) > (distance s1_0 s2_1) do swap s2_0 s2_1
				i = addnewspline sp
				addknot sp i #corner #line s1_0
				addknot sp i #corner #line s2_0
				k = addnewspline sp
				addknot sp k #corner #line s1_1
				addknot sp k #corner #line s2_1
				setsplineselection sp #(s1)
				ok
connectTwoSplines()
Message 7 of 9
Alfred.DeFlaminis
Hello @Anonymous,
Did the incredibly amazing post by @denisT.MaxDoctor help with this issue?  Are you all set now?  Thanks for the information!
Best Regards,
Message 8 of 9
Look, could you help me, please? I wanted a similar script so I would like to do 3 lines that are on the axis if they fudge and
Message 9 of 9
denisT.MaxDoctor
usually a picture can explain the problem better... draw what you have before and want to have after alignment/welding
