script to change output of Display Coordiantes
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Greetings, I'm wondering if there's a way I change the output values for coordinate display window at the bottom of the screen to be HEX?.
An example of a typical coordinate display is in float value like this:
X: 13.880514 Y: 0.0112 Z: -9795.024
I need to have the coordinate display window multiply these values by 1000 and then make a simple conversion. Example of conversion:
X = 13.880514 x 1000 = 13880.514
The value of 13880.514 converted to HEX is: 46 58 E2 0E, and is in Big Endian byte order, but I need it in little Endian like this 0E E2 58 46
Is there a script, pluggin, or method I could do to make this work?
