Announcements
RollUp custom color in 2017
Message 1 of 10
is there a way to modify the rollup color as it was in previous versions. Maybe a script ... the documentation COLORMAN there but I do not write the script. In the previous version it has seemed clearly arranged navigation. or just title text color.?
Replies (9)
Message 2 of 10
Any info!?
Message 3 of 10
sehindel_19
Message 4 of 10
I know that but how to change RollUp title background. Look a picture on top. Orange Color!
Message 5 of 10
sehindel_19
in resource editor for the idc_panel
soething like this perhaps or similar
propertysheet for the dialog(style color etc)
exempel
https://social.msdn.microsoft.com/Forums/vstudio/en-US/4b268c1c-acd1-45df-af7b-657768a7f366/how-does...
full example source
http://www.tenouk.com/mfcproject/mymfcpro/
idc_color =mcolor; stringtable
// CPage3 property page
IMPLEMENT_DYNCREATE(CPage3, CPropertyPage)
CPage3::CPage3() : CPropertyPage(CPage3::IDD)
//{{AFX_DATA_INIT(CPage3)
m_nColor = -1;
//}}AFX_DATA_INIT
CPage3::~CPage3()
BOOL CPage3::OnCommand(WPARAM wParam, LPARAM lParam)
SetModified(TRUE);
return CPropertyPage::OnCommand(wParam, lParam);
void CPage3::DoDataExchange(CDataExchange* pDX)
TRACE("Entering CPage3::DoDataExchange -- %d\n",
pDX->m_bSaveAndValidate);
CPropertyPage::DoDataExchange(pDX);
//{{AFX_DATA_MAP(CPage3)
DDX_Radio(pDX, IDC_COLOR, m_nColor);
//}}AFX_DATA_MAP
BEGIN_MESSAGE_MAP(CPage3, CPropertyPage)
//{{AFX_MSG_MAP(CPage3)
// NOTE: the ClassWizard will add message map macros here
//}}AFX_MSG_MAP
END_MESSAGE_MAP()
// CPage3 message handlers
Message 6 of 10
sehindel_19
or u have (parent's OnPaint method)
CPaintDC dc(this); // device context for painting
 CRect rc;
 CWnd * pW = this->GetDlgItem(IDC_GROUPBOX);
 pW->GetClientRect(&rc);
 pW->ClientToScreen(&rc);
 this->ScreenToClient(&rc);
 dc.FillSolidRect(&rc,RGB(255,0,0));
or on N_WM_CTLCOLOR  method
if( pWnd->GetDlgCtrlID () == ???)
return hBGBrush;
}//optional
HBRUSH CTestprogrammDlg::OnCtlColor(CDC* pDC, CWnd* pWnd, UINT nCtlColor)
// Brush für den Dialog Hintergrund anlegen
HBRUSH hBGBrush = CreateSolidBrush(RGB(128, 184, 223));
// Brush für Dialog Hintergrund zurück geben
return hBGBrush;
check this link https://www.codeguru.com/cpp/controls/editctrl/backgroundcolor/article.php/c3929/Changing-the-Backgr...
Message 7 of 10
but how can i implement in 3ds? EXE!? I don't anything about programing/scripting!
Message 8 of 10
sehindel_19
i assumed u were a programmer since this is the programming forum for 3d max, but my bad then 😞
then i guess i cant help you. best of luck to u i hope u find what u seek
Message 9 of 10
ulrich.haberl
I'm sorry, but it's not possible in 3dsMax 2017 any more. The painting code of the rollup titles has internally been moved to Qt, and the new design does not use some of the previous customization options any more.
I know that there were some discussions with our UI designers about that, since the rollup now is more some plain area, the title itself has no border any more, what makes it kind of hard to decide where a different background should end - but it would be doable, of course.
If you want that possibility back, please add a feature request here https://knowledge.autodesk.com/contact-support/technical-support or via ADN.
Ulrich
Message 10 of 10
istan
i already informed AD several times, that the programming board is flooded with ricochets..
I suggested them to rename the board to "C++, Phyton, MXS programming" instead of naming it "3ds Max.."
It's the only board using "3ds max" in its topic name, when displayed on mobile devices..
