Announcements
maxScript
maxScript
Message 1 of 12
maxScript
Hello guys,
Can any one help me need script that create polygon from verices each vertex is 3d point
Then assign material to it
Accepted solutions (3)
Replies (11)
Message 2 of 12
Swordslayer
vertices = #([43,-20,0], [27,8,0], [-6,8,0], [-23,-20,0], [-6,-50,0], [27,-50,0])
obj = convertToPoly (mesh vertices:vertices faces:#())
polyOp.createPolygon obj #(1,2,3,4,5,6)
obj.material = standardMaterial()
redrawViews()
Message 3 of 12
But need to add material from jpg file on my computer
Message 4 of 12
Swordslayer
In that case replace the standardMaterial() part with standardMaterial diffuseMap:(bitmapTexture filename:@"C:\path\to\texture\filename.jpg")
Message 5 of 12
unfortunately tried this but not work
Message 6 of 12
Swordslayer
That's like.. super unhelpful. You're doing something wrong and without showing the code/error message or telling me what expectations of yours aren't met, it's impossible to tell you what to change. Does the file exist at the path? When you pick the material from the object, is there anything wrong? Maybe you just wanted the texture to show in the viewport (which it doesn't by default) or maybe you wanted to apply mapping as well or... well, you tell me, I could guess all day and still not get it.
Message 7 of 12
sorry i am newer to maxscript
when i add image file from my folder it appear as standardmaterial
but when drag and drop it appear color of material not texture itself
these images
Message 8 of 12
i tried to solve it by
add this line
showtexturemap mat true
as code to draw face became
depth = 100
width = 100
vertices = #([0, 0, 0],[width, 0, 0],[width, depth, 0],[0, depth, 0] )
polyOp.createPolygon obj #(1,2,3,4)
img_path = "E:/images.jpg"
mat=standardmaterial();
mat.diffuseMap = bitmapTexture filename:(img_path)
obj.material=mat
redrawViews()
now it work like drag and drop but this and drage and drop not clear as whenn create plan
these 2 image can explain
Message 9 of 12
add this line
depth = 100
width = 100
obj.material=mat
redrawViews()
Message 10 of 12
Swordslayer
That's because there's no mapping info, you can either add a uvwmap modifier with given size or use the polyop methods to add the mapping/mapping verts+faces.
Message 11 of 12
polyop.applyUVWMap <Poly poly> \
<#planar | #cylindrical | #spherical | #ball | #box> | <#face> \
utile:<float=1.0> vtile:<float=1.0> wtile:<float=1.0> \
uflip:<boolean=false> vflip:<boolean=false> wflip:<boolean=false> \
cap:<boolean=true> tm:<Matrix3=identity matrix> channel:<integer=1>
found this map but also not work well
Message 12 of 12
worked well by this line
polyop.applyUVWMap poly\
#face \
