Restore DockWidget Dock Area
richecoeur.m
richecoeur.m
I am trying to dock a QDockWidget on the left using Pyside. But the addDockWidget function doesn't seem to work :
3dsMax_Main_Window.addDockWidget(DockWidgetArea.LeftDockWidgetArea,my_dock_widget)
I also tried using QMainWindow restoreState() and saveState() functions.
Can you provide a snippet on how to manage this in 3dsmax 2022 ?
Thank You for your help.
richecoeur.m
Found the solution, just call my_dock_widget.setFloating(False) after adding your dockwidget to mainwindow:
Demonstrates how to create a QDockWidget and Dock it to the left with PySide2 for use in 3ds Max
from PySide2 import QtCore
from PySide2 import QtGui
from PySide2 import QtWidgets
import qtmax
from pymxs import runtime as rt
def make_cylinder():
    cyl = rt.Cylinder(radius=10, height=30)
    rt.redrawViews()
    return
class PyMaxDockWidget(QtWidgets.QDockWidget):
    def __init__(self, parent=None):
        super(PyMaxDockWidget, self).__init__(parent)
        self.setWindowFlags(QtCore.Qt.Tool)
        self.setWindowTitle('Pyside Qt  Dock Window')
        self.initUI()
        self.setAttribute(QtCore.Qt.WA_DeleteOnClose)
    def initUI(self):
        main_layout = QtWidgets.QVBoxLayout()
        label = QtWidgets.QLabel("Click button to create a cylinder in the scene")
        main_layout.addWidget(label)
        cylinder_btn = QtWidgets.QPushButton("Cylinder")
        cylinder_btn.clicked.connect(make_cylinder)
        main_layout.addWidget(cylinder_btn)
        widget = QtWidgets.QWidget()
        widget.setLayout(main_layout)
        self.setWidget(widget)
        self.resize(250, 100)
def main():
    rt.resetMaxFile(rt.name('noPrompt'))
    main_window = qtmax.GetQMaxMainWindow()
    w = PyMaxDockWidget(parent=main_window)
    main_window.addDockWidget(QtCore.Qt.LeftDockWidgetArea,w)
    #w.show()
    w.setFloating(False)
if __name__ == '__main__':
    main()
