Restore custom toolbar's position in a plugin
What is the best practice for restoring the position of a custom toolbar after Max has been restarted?
I see that the toolbar's config gets written to the user's workspace .cuix file when closing Max. But what do I need to do to restore these settings?
The SDK samples do not really give a hint on how to restore that.
It's a GUP-type plugin. The toolbar ist created with these commands
CreateCUIFrameWindow()
GetICUIFrame()
CreateWindow(CUSTTOOLBARWINDOWCLASS,....)
LinkToCUIFrame()
Toolbar->AddTool()
DockCUIWindow()
Thanks, Elio
petkus09
I'm currently working with this problem. Looked through .cuix file syntax. The key point lies with the toolbar's <window> tag's attribute 'type'.
To restore the toolbar after the restart, it's value should be set to type="T" .
Currently my custom toolbars have type="N" property, which is not restored after the restart or by loading custom UI file.
The problem is how to change the type property from N to T in code.
I hope someone has some insight.
petkus09
Wew. Found the answer at http://forums.autodesk.com/t5/programming/custom-toolbar-to-appear-when-right-clicking-on-main-toolb...
in C#, you change SystemWindow property to true for frame object.
Man Happy
Wow, thank you so much. That did it.
You made my day!
petkus09
No problem. Don't forget to close the topic.
