Rename Objects
Rename Objects
dg3duy
Rename Objects
dg3duy
I need to write a new name to replace the word Character that already contains each of the objects in my scene with a new name that I can write.
My objects are called: Character_Nametest_001///Character_Othername_001///Character_Test_001
Ideally, you should use a menu like the one in this exercise:
macroScript RenameThem category: "HowTo"
 rollout rename_rollout "Enter New Base Name"
  edittext base_name ""
  button rename_them "RENAME SELECTED OBJECTS..."
  on rename_them pressed do
   if base_name.text != "" do
    for i in selection do i.name = uniquename base_name.text
  )--end on
 )--end rollout
createDialog rename_rollout 250 50
10DSpace
@dg3duy
Just making sure that you do know that the Rename Objects Tool in the Max Tool menu already let's you do this by removing the first 9 digits and putting your replacement name as a prefix:
dg3duy
It's not a bad idea to use it, it's just that I'd like to see it on the menu I show you below.
denisT.MaxDoctor
macroScript NameChange
	category: "MXS with denisT"
	buttonText:"NAME CHANGE"
	toolTip:"Name Change with denisT"
	autoUndoEnabled:off
	silentErrors:off
	local d
	global NameChangeRol =
		rollout NameChangeRol "Object Name Change" width:191
			local opened = if opened != undefined do opened
			local dialog_pos = if dialog_pos != undefined then dialog_pos else unsupplied
			local source_text = if source_text != undefined then source_text else ""
			local target_text = if target_text != undefined then target_text else ""
			edittext source_name_ed "Source:" text:source_text fieldwidth:130 align:#right offset:[8,4]
			edittext target_name_ed "Target:" text:target_text fieldwidth:130 align:#right offset:[8,0]
			on source_name_ed changed text do source_text = text
			on target_name_ed changed text do target_text = text
			button name_replace_bt "Replace" width:180 align:#right offset:[8,0] \
				tooltip:"Replace Source part of object name with Target"
			button name_casechange_bt "Change Case" width:180 align:#right offset:[8,2] \
				tooltip:"Change object name case\n    Default\t - To Lower\n  +SHIFT\t\t - To Upper"
			on name_replace_bt pressed do undo "Name Change" on if source_name_ed.text.count > 0 do
				for obj in selection do obj.name = substitutestring obj.name source_name_ed.text target_name_ed.text
			on name_casechange_bt pressed do undo "Name Change" on
				for obj in selection do obj.name = (if keyboard.shiftPressed then toupper else tolower) obj.name
			on NameChangeRol close do
				dialog_pos = getdialogpos NameChangeRol
				opened = off
				updateToolbarButtons()
			on NameChangeRol open do
				opened = on
	fn destroy =
		try(destroydialog d) catch()
	fn create =
		createdialog d pos:d.dialog_pos
	fn enabled =
		iskindof (d = try(globalvars.get #NameChangeRol) catch()) RolloutClass
	on isChecked do enabled() and (d.opened == true)
	on execute do if enabled() do
		if (d.opened != true) then create() else destroy()
I hope you know how to add Macroscript to the system
dg3duy
it works as usual on your part... wonderfully!
Thank you very much!
