Announcements
Remove standard Mtl, Unwrap UVW
n_stylee
Message 1 of 14
n_stylee
Hello i am trying to remove all standard materials in the scenes?
For some reason when you are  using UVW Unrwap , its creating a standard Mtl  for the  unrwap in the scene and there is no way get rid of it!
Yes when i collapse the object to Editable Poly its gone, but this is not a solution . I can see the Mat. in the asset tracker ,but again i connot remote  it.
If someone have  an idea please help 🙂
Replies (13)
Message 2 of 14
denisT.MaxDoctor
what do you want to do with these two materials? (there are two materials made by Unwrap_UVW)
Message 3 of 14
denisT.MaxDoctor
for example, let's replace with "undefined":
fn replaceUnwrapMaterials modi mat:undefined = if iskindof modi Unwrap_UVW do
	mats = getclassinstances standard target:modi
	pb2 = for k=1 to refs.getNumRefs modi where iskindof (pb2 = refs.getreference modi k) ParamBlock2 do exit with pb2
	for k=1 to refs.getNumRefs pb2 where finditem mats (refs.getreference pb2 k) > 0 do
		refs.replacereference pb2 k mat
	mats
-- replaceUnwrapMaterials <unwrap_uvw modifier>
Message 4 of 14
n_stylee
Thank you so much for the fast answer!
I want to delete them from the scene. In the end to  have zero standard mtls. in the scene and to keep the unwrap unstacked.
Message 5 of 14
n_stylee
The other option is to convert the Standardm tls to Vray, but in the end again the goal is two have zero standard mtls in the scene.
Whatever is the easiest  way to do it.
Message 6 of 14
n_stylee
The scripts to convert  scene materials don't work in this case.
Maybe because the materials are created from the unwrap modifier
and they are in the uvw sub level.
So far  i was able to convert one of the standard mtl to vray
with this :
$.modifiers[#Unwrap_UVW].TextureCheckerMaterial = VrayMtl ()
but i cannot do the same with the  Unwrap Checker  material.
The workaround for the Unwrap Checker Mtl. is to "pick it"  in the Material Editor
and then to  manually convert it to VrayMtl. This way is slow and no good because
every Unwrap uvw  modifier is creating 2  standard materials, so annoying.
Message 7 of 14
domo.spaji
What's the idea behind all that? Why are you so afraid of standard material?
Message 8 of 14
n_stylee
When you are working in a heavy Vray scene ,the standard mtl is crashing Max. Every unwrap modifier is creating 2 separate standard materials . If you have  5 unwrapped objects,  automatically you are getting  10 standard mtls ,
(x 2 buried under each modifier)! The scripts that are converting materials cannot see them to,  but they are in the scene .
Yes you can stack after modifier and they are gone,  but that way you are Locking the geometry.
Message 9 of 14
denisT.MaxDoctor
This is a big problem! Something is wrong with your system if the standard materials break it. First, you must find a reason why.
Message 10 of 14
n_stylee
Yes indeed is a big problem.
  I am talking about a  scene with million vertex's, proxies, vray mtls( with no translucency) rail clone and forest -(all licensed plug-ins).
And yes  i found the issue, its the standard materials.
For  right now  i can clean the  2 materials
on a single selected object with this:
$.modifiers[#Unwrap_UVW].TextureCheckerMaterial = undefined
$.modifiers[#Unwrap_UVW].checkerMaterial = undefined
Can pls someone help me to modify it so it will work for all selected objects or for all abjects in the scene that have unwrap modifier.
Message 11 of 14
denisT.MaxDoctor
mapped fn replaceUnwrapMaterials modi mat:undefined = if iskindof modi Unwrap_UVW do
	mats
replaceUnwrapMaterials (getclassinstances Unwrap_UVW)
Message 12 of 14
n_stylee
Thank you so much !
I really appreciate it!
Message 13 of 14
denisT.MaxDoctor
try to understand why the standard materials are causing problems in your scene. What viewport rendering (shading) are you using?
I am sure that the standard material is the safest MAX material for any scene. Only certain (custom) MAX settings can cause corresponding instability.
what you are doing now is hiding the problem, not treating it.
Message 14 of 14
n_stylee
Yes  i completely agree with you.
I suspect its the combination from
 the Forest pack, Rail clone and Vray.  Its  not happening often, but when it  does removing the Standard mtl from the scene is doing the trick.
Again thank you for  your time.
