reading/writing a CS .fig file (ASCII)
Hiya ...
I recently realized that a biped figure file (.fig) is in ASCII format ..
I 'm writing a tool to build a biped from scratch thro maxscript using some values I have in a file.
These values that I have are the world transform matrix values of each joint.
If I could understand the values found in a .fig file, that'd be a great start point ...
Does anyone have the know how of the structure of a .fig file?
This is what I've figured out till now:
# A fig file has integer values like 10,11,12,13, and so on, which I presume are some kind of IDs corresponding to various Biped parts.
for eg, I guess
11 : Spine
12 : Head
13 : Neck
101 : COM
Am still trying to figure out the rest.
The number of links of a biped part, I guess, is stored as a integer value which is (numLinks * 3)
Another important value found in the file is the distance between a joint and the next child, in max units.
11 ##SPINE
3
21.796455
eg: If the number of spine link is 1, then the spine ID 11 is followed by the value 3.
If numSpineLinks == 2 then spine ID 11 would be followed by 6 (2 * 3)
21.796455 could be the distance between the spine joint and its child, the neck joint.
It also seems that the matrix values stored in the .fig file are using Y -UP, maya style, instead of max styled Z-UP.
Any gurus out there who could shed more light on this file format, highly appreciated.
Thanks in advance
regards,
shibu
The indices are listed in the mxs docs...
Search for "biped"
Biped Node Hierarchy is the heading you are after.
no mate, its not the same.
The Ids found in .fig files are completely different than the ones that we normally use in scripts
Try this :
Save a .fig file off any biped and open the fig file in any text editor.
