oscilloscope algorithms (with pictures)
Message 1 of 16
Hi gang,
I've been away for a while, but I'm back maxing and need some help.
I'm trying to mimic an oscilloscope via maxScript but I'm having trouble figuring out the code to make some of the basic shapes. I know that numbers on the attached images refer to the ratio between two sine waves used generate the shape. 1:1 being a unison 2:1 being an octave 4:3 is a 4th and 3:2 is a 5th. (The unlabeled ones are of a tighter interval or possibly of more than two sine waves.) But try as I might, I don't know how to get from the two sin functions to points in 3d space. If anyone knows anything about oscilloscopes, or these sinusoidal shapes in general, any help would be great.
Thanks in advance,
James
Replies (15)
Message 2 of 16
And wada ya know. The second I post this, I figure it out. If anyone's interested it looks something like this:
pts = 36 -- the number of points in the spline
rat = 2.0/3.0 -- the ratio of the two frequencies
for n = 0 to pts do (
deg = (360/pts)*n
x = sin deg*rad
y = cos deg*rad
z = sin (deg/rat)*rad
Message 3 of 16
stigatle
Cool, thanks for sharing the code with us 🙂
Message 4 of 16
Have to say... they look great. I don't know why I didn't come up with this before. I'll post the final result when it's done.
Message 5 of 16
stigatle
You can probably drive it by audio also? wave controller?
Message 6 of 16
Steve_Curley
Lissajous curves
And welcome back btw 🙂
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
Message 7 of 16
Lissajous curves
Sweet. I had no idea what they were called so I couldn't look them up.
And it's good to be back, thanks.
Message 8 of 16
You can use the audio control to affect the ratio, yes, but it won't be 'real'. Max doesn't have the sound processing capabilities to analyze the frequencies on the level needed to get anything like real sound wave data out of a file. But it does work for 'faking it'.
Message 9 of 16
So, here's a little animatic I made for a radiohead video contest. It uses lissajous curves and varies the ratio between the frequencies to the beat. Looks pretty cool if you ask me. I also wrote a script that would project these curves onto any geometry (in this case, a model of the lead singer's head), still keeping the curve's animation. The encoding isn't great because there's so much movement, but I think you get the idea.
You can see the vid here. (and if you like, sign up and vote...)
Thanks, guys.
james
Message 10 of 16
And while I'm here, I might as well update the code a bit. The new element is 'wraps' which allows you to decide how many times to wrap the line around. For non-rational frequencies, the more wraps, the more lines. For rational frequencies, the line will eventually meet up with itself.
fn posOsc rad rat segs wraps = (
-- rad: the radius of the circle
-- rat: the ratio between the two frequencies
-- segs: the number of segments in the spline
-- wraps: the number of times to wrap the spline around the 'cylinder'
for n = 0 to segs do ( -- note: there is one more knot than segments
deg = ((360*wraps)/segs)*n
px = sin deg*rad
py = cos deg*rad
pz = sin (deg/rat)*rad + rad -- shift up by rad so it sits on the ground plane
-- position knot number n to
Message 11 of 16
joshpurple
Cool! You got my vote James! 🙂 And Thanks for the code.
Message 12 of 16
I'm going to sound really really ignorant here (probably because I am), but I don't know how to use the code:
deg = (360/pts)*n
x = sin deg*rad
y = cos deg*rad
Do you apply it to an existing spline, embeed an Spline creation to the macro or do something compleatly diferent?
Message 13 of 16
Steve_Curley
I would guess he's using that algorithm to create a new spline object.
Max 2016 (SP1/EXT1)
Message 14 of 16
You can use it to create a single spline, but if you want to change the ratio over time (which is what I did in the video) you need to create a spline with the desired number of points; set the points to "smooth" if they're not already; apply a spline IK control modifier and click the "create helpers" which will create a helper object for each point and then run the posOsc function, replacing the "-- position knot number n to " with something like, "getNodeByName ("point" + n as string).pos = ". If you do this in an "animate on" context over time, you'll see the spline animating over time.
Does that help? Maybe I'll work up a start to finish example when I have a second...
Message 15 of 16
ok - here goes...
First run this:
segments = 36
fn makeOsc = (
osc = splineShape()
osc.adaptive = true
osc.render_renderable = true
osc.render_displayRenderMesh = true
osc.render_thickness = 1
osc.render_rectangular = false
osc.render_sides = 12
addNewSpline osc
for n = 0 to segments do (
pt =
addKnot osc 1 #smooth #curve pt
updateshape osc
spik = spline_ik_control()
addmodifier osc spik
This creates a spline with 36 segments with a spline ik modifier. I couldn't get the next step to work via script and don't have time to figure it out (if anyone knows how, please let us know) so just select the spline by hand and click 'create helpers' and make sure the 'link types' is set to 'no linking'.
Now run this:
segments = 36
px = sin deg*rad
py = cos deg*rad
if n < 9 then nstr = ("0" + (n+1) as string) else nstr = (n+1) as string
(getNodeByName("Point" + nstr)).pos =
startRat = 1.0
endRat = 0.1
startFrame = 0
endFrame = 100
for t = startFrame to endFrame do
with animate on
at time t
posOsc 100 (startRat+((startRat-endRat)/(endFrame-startFrame))*t) segments 4
You should have the spline animated from frame 0 to 100.
Now you can play with the start and end ratios to see what the shape does. Simple fractions will give you simpler shapes (1:1, 1:2, 2:3, 3:4...) the tighter the numbers, the more lines you get. Also play with the wraps variable. The more wraps, the more complex the line, but the less smooth the curve. If you really want to test your box, start again and set segments to 360 or higher and you can see how complex these shapes can get.
Message 16 of 16
Thank you very much.
