Randomize
Randomize
GeoffKornfeld
Message 1 of 10
Randomize
GeoffKornfeld
I have several dozen proxies that I want to randomize the the animation offset of. I know how to change the parameter to a specific number on a selection, but I don't know how to tell maxcript to enter random numbers between 1 and 570.
Thanks.
Replies (9)
Message 2 of 10
denisT.MaxDoctor
either the question is not accurate or the answer is obvious:
random 1 570
... and of course you can specify a seed value (see random and seed in the MXS Help)
Message 3 of 10
GeoffKornfeld
Thanks, but that command gives everything in the selection the exact same random number. I want each object to get a different number.
Message 4 of 10
GeoffKornfeld
I guess I should specify that these are VRay Proxy objects, and I just entered the command:
($). anim_offset = random 1 570
Message 5 of 10
denisT.MaxDoctor
if all your VRay proxy objects have a unique name, we can generate a random offset value based on the name:
	hashcode = gethashvalue <vray_proxy_obj>.name 0
	seed hashcode
	<vray_proxy_obj>.anim_offset = random 1 570
where <vray_proxy_obj> is a "pseudo node" variable
Message 6 of 10
GeoffKornfeld
Sorry, I'm not understanding. And I'm not clear on how to modify what you typed to to work. Each of my objects is called "Goat 001, Goat 002.... etc." (they are grazing goats on a field). Should the name matter? Can't there just be a script that finds the parameter in the selected objects one by one and put a random value in there?
Message 7 of 10
denisT.MaxDoctor
1. select all vray proxy objects
2. run this script:
for vray_proxy_obj in selection do
	hashcode = gethashvalue vray_proxy_obj.name 0
	seed hashcode
	vray_proxy_obj.anim_offset = random 1 570
every time you do it each object will get exactly the same but random number based on seed value generated using the object's name. of course all names must be unique.  the objects with the same name will get the same random number
Message 8 of 10
denisT.MaxDoctor
how many objects do you have and want to randomize?
Message 9 of 10
denisT.MaxDoctor
simple using of random method cannot for sure guaranty exactly unique numbers for all objects.
if the number of objects is less than the number of possible "offsets" I would probably use shuffle method instead of random
Message 10 of 10
GeoffKornfeld
Oh I see. My problem was that I was trying to run the script from the listener. I dragged it to the toolbar and it worked great. Thank you!
