"Unable to convert OK to type:Float" error
bhnh
bhnh
Here's a bit of code to make a checkbox in one object hide/unhide another object...
ca = attributes New
parameters main rollout:params
hidestuff type:#boolean ui:ckb_hs
rollout params "Checkbox Controller"
checkbox ckb_hs "Hide Unselected Stuff"
on ckb_hs changed theState do
(print this.hidestuff)
rollout demo "CustAtt Checkbox Demo"
button btn "Make Shapes"
on btn pressed do
s = sphere radius:12
c = cone pos:
custAttributes.add s ca
s.hidestuff = false
watcher = point()
watcher.parent = s
fs = float_script()
watcher.axistripod.controller = fs
fs.addNode "ctrlBall" s
fs.addNode "coneshape" c
fs.script = "with animate off (if ctrlBall.hidestuff == true then hide coneshape else unhide coneshape)"
createDialog demo 200 50
When I evaluate, I get the following error:
-- Runtime error: IScriptCtrl::SetExpression - Expression evaluation error:
-- Unable to convert: OK to type: Float
Any clues for the clueless here? Many thanks.
I think I see it: fs.script is supposed to return a Float value at the end. Hide and unhide both return OK.
bhnh
That's it, Stokes. Tyson Ibele over at SimplyCG pointed out that simply adding \n 0 to the end of the fs.script solves the problem...
ca = attributes New
on btn pressed do
c = cone pos:
s.hidestuff = false
watcher = point()
watcher.parent = s
fs = float_script()
fs.script = "if ctrlBall.hidestuff == true then hide coneshape else unhide coneshape\n 0"
Run the code, check the box, click on the time slider (or animate) and voila.
