Quick weighting script not working on 3ds max 2016 !
02:10 AM
- Mute
- Permalink
- Report
in case you don't know , the quck weighting script allows you to press a key (that you'll set in costume user interface ) then move your mouse to change the weight value on any selected vertexes .
if you ever made a rig , or tried making one , you'd know how tedious it is , this script can be a real time saved .
macroScript QuickSkinVertexWeight category:"Custom Skin Tools" tooltip:"Quick Vertex Weight Tool" ( tool AssignSkinVertexWeightTool ( local original fn setweight wt = ( if (wt < 0) then wt = 0 if (wt > 1.0) then wt = 1.0 skinOps.setWeight $.modifiers[#Skin] wt $.modifiers[#Skin].effect = wt ) on mousePoint clickno do ( if clickno > 1 then return #stop original = $.modifiers[#Skin].effect ) on mouseAbort clickno do ( setweight original ) on mouseMove clickno do ( newval = (original + (gridDist.x * 0.01)) setweight newval ) ) startTool AssignSkinVertexWeightTool prompt:"Set Vertex Weight" )
when using it , a message appears saying " --No ""+"" function for undefined " , as you can see in the attached pic
if you want to see what happens when it works : https://youtu.be/Ya02rmjNsUM?t=6m26s
