Python - Using core interfaces (and named selection sets)
federico.ciuffolini
federico.ciuffolini
Hi guys,
my end goal is to have access to the Named selection sets system using python.
I couldn't find anything in the documentation, but I noticed that inside MaxPlus.InterfaceIds there is a IidNamedSelectionSetManager interface. Am I on the right path? How can I access this interface?
The only evidence i was able to Reverse engineer is that if you do something like:
interface = MaxPlus.Core.GetCOREInterface(MaxPlus.InterfaceIds.IidNamedSelectionSetManager)
print(interface.FindFn("GetNamedSelSetItemCount"))
you get a nice "2" as output, instead of the -1 that you get if you put in other gibberish.
I know that something is hiding in there. But I don't know how to access and use it.
Any insight?
Thanks!
drew_avis
Hi Frederico, I would encourage you to look at using pymxs instead of MaxPlus for this task, for (as you've noticed) MaxPlus does not directly expose the NamedSelectionSetManager, while Maxscript (and therefore pymxs) does.
You can do something like:
import pymxs
rt = pymxs.runtime
named_mgr = rt.NamedSelectionSetManager
num_sets = named_mgr.GetNumNamedSelSets()
print num_sets
for i in range(num_sets):
	print named_mgr.GetNamedSelSetName(i)
	print named_mgr.GetNamedSelSetItemCount(i)
This doc covers the methods you can use:
https://help.autodesk.com/view/3DSMAX/2019/ENU/?guid=GUID-6CC6500C-FD5C-4646-A880-BC34E852CA2B
Hope that helps,
Drew
Drew Avis
Content Experience Designer
federico.ciuffolini
Thank you ! That is way more simple.
Federico
