Announcements
Python: SetCurrentLayer broken?!?
jens.diemer
jens.diemer
Simple example code:
import MaxPlus
MaxPlus.LayerManager.CreateLayer("foobar")
MaxPlus.LayerManager.SetCurrentLayer("foobar")
A "foobar" layer will be created, but SetCurrentLayer() will result in a error:
-- Error occurred in anonymous codeblock; filename: test.ms; position: 250; line: 6
-- Runtime error:  Line 39  run()
 Line 30210  SetCurrentLayer()
  <type 'exceptions.NotImplementedError'> Wrong number or type of arguments for overloaded function 'LayerManager_SetCurrentLayer'.
  Possible C/C++ prototypes are:
    Autodesk::Max::LayerManager::SetCurrentLayer(Autodesk::Max::WStr const &)
    Autodesk::Max::LayerManager::SetCurrentLayer()
Why?
Jens
https://github.com/jedie/3dsmax_bugs | https://github.com/jedie/3dsmax_patches
kevinvandecar
Sorry, but yes it appears this method is not implemented properly. In fact, it appears that any of those APIs athat are using a paramater of WStr as shown in the documentation are broken.
I have reported this as a defect: MAXX-22973
thanks,
kevin
Kevin Vandecar
Developer Technical Services
Autodesk Developer Network
