pymxs modifiers gizmo set position doesn't work like in MaxScript
stevkalinowski
stevkalinowski
I'm trying to set a modifier gizmo's position using pymxs, but it doesn't seem to work like it does in Max Script.  When I execute this code I don't get an error, but nothing happens.
# Select an Editable Poly object, then execute this
import pymxs
pymxsRt = pymxs.runtime
s = pymxsRt.selection[0]
newMod = pymxsRt.UVWMap()
newMod.axis = 1
newMod.channel = 0
newMod.mapChannel = 2
pymxsRt.addModifier(s, newMod)
# does not work
s.modifiers[0].gizmo.position = pymxsRt.Point3(0,0,0)
# This doesn't work either
# s.modifiers[0].gizmo.position = [0,0,0]
Am I missing something?
drew_avis
Hi, thanks for asking about this - I've confirmed that it's a bug, and have logged a defect.  I will do a bit of research and see if I can find a usable work-around.
Drew
Drew Avis
Content Experience Designer
stevkalinowski
Got it, thanks.
drew_avis
A developer looked into this, and it looks like a timing issue - the gizmo does not yet exist until the modifier is added to the object, AND the scene is re-drawn.  This happens after the python script completes.  One solution is to force a redraw before trying to modify the gizmo.  Here's a sample script:
from pymxs import runtime as mxs
b = mxs.box()
mod = mxs.UVWMap()
mod.axis = 1
mod.channel = 0
mod.mapChannel = 2
mxs.addModifier(b, mod)
mxs.completeRedraw() # redrawViews() also works
gizmo = b.modifiers[0].gizmo
print mxs.getProperty(gizmo, 'position')
mxs.setProperty(gizmo, 'position', mxs.Point3(0,0,0))
We will be adding this sample and a description of the issue to the docs.  Thanks again for pointing this out.
Drew
Drew Avis
stevkalinowski
Tested on my end and it works.  Thanks!
