Projection modifier: I'm trying to project UV channel 2 from multiple LOD0 objects, to the correspond LOD1 and LOD2, by maxscripting
unmarti
Message 1 of 9
unmarti
Hello there,
I created the following macroscript, with the intention of projecting UV map channel 2, from multiple selected objects (LOD0), to their corresponding low resolution objects (LOD1 and LOD2):
macroscript MyCustomTool2
category:"MyTools"
tooltip:"Project UVs multiple LOD0"
	rollout projectMutipleUVsRollout "Project UVs"
		button projectMutipleUVsButton "Project UVs"
		on projectMutipleUVsButton pressed do
			-- Retrieve the selected objects
			local selectedObjects = selection as array
			-- Check if any objects are selected
			if selectedObjects.count > 0 then
				-- Loop through each selected object
				for z = 1 to selectedObjects.count do
					-- Add Projection modifier to the selected object
					local obj = selectedObjects[z]
					local projMod = Projection ()
					addModifier obj projMod
					-- Get the name of the selected object
					local objName = obj.name
					-- Extract the base name
					local baseName = substring objName 1 (objName.count - 1)
					-- Iterate through all objects in the scene
					for i = 1 to objects.count do
						local currObj = objects[i]
						local currObjName = currObj.name
						-- Check if the object name matches the pattern
						if (findString currObjName baseName) == 1 and (currObjName != objName) do
							--Add the matched object to the Reference Geometry List
							projMod.addObjectNode currObj
					--Add a Projection Mapping
					projMod.addRegisteredProjectionType 1
					pMap = projMod.getProjectionType 1
					--Get that Projection Mapping for work with it
					--Assign UV map channels
					pMap.sourceMapChannel = 2
					pMap.sameAsSource = false
					pMap.targetMapChannel = 2
					projMod.projectAll()
				-- Display a message
				messageBox "UV projection completed."
			else
				-- Display a message if no objects are selected
				messageBox "No objects selected." title:"Error"
	createDialog projectMutipleUVsRollout 250 50
If I only select one object (LOD0), it works perfectly, but when I select multiple objects, I don't understand why, but "projMod.addRegisteredProjectionType 1" doesn't seem to work, and the code breaks after that. So, if any one could explain to me why these is happening, and give me some solution, I'll be really grateful. Thanks for your time.
Replies (8)
Message 2 of 9
denisT.MaxDoctor
Why code as a .PNG image? To have fun with the conversion?
Would you prefer an answer in ancient Egyptian to continue the fun?
Message 3 of 9
unmarti
Sorry Denis, this is my first post, I still have a lot to learn. But no please,
ancient Egyptian is not one of my best languages.
Message 4 of 9
denisT.MaxDoctor
so post the code again as text please.
Message 5 of 9
unmarti
Thanks for the minitutorial Denis
Message 6 of 9
denisT.MaxDoctor
the system tries to avoid a "dependency loop" and cannot add a target with an already added source as a target in another projection modifier. Thus, it is necessary to check and determine which targets should be excluded from the projection.
more specifically...
if the list of projected targets is empty, the projection modifier returns an undefined projection object with (pmod.getProjectionType 1)
Message 7 of 9
denisT.MaxDoctor
for example:
mapped fn add_projection_mod obj targets: =
	local pmod = Projection()
	-- make the projection modifier a current edit object:
	max modify mode
	select obj
	modPanel.addModToSelection pmod
	if targets == unsupplied do targets = geometry as array
	for target in targets do --> where not refs.DependencyLoopTest target obj do
		----- the system checks for dependency loop >>
		pmod.addObjectNode target
	pmod.addRegisteredProjectionType 1 -- works only if pmod is a current edit ModPanel object:
	if (pobj = pmod.getProjectionType 1) != undefined do
		--format "object:% map:%\n" obj pobj
		pobj.sourceMapChannel = 2
		pobj.sameAsSource = false
		pobj.targetMapChannel = 2
		pmod.projectAll()
delete objects
for k=0 to 3 do box pos:[k*40,0,0]
select objects
add_projection_mod (selection as array)
Message 8 of 9
unmarti
Wow! That works perfectly! Thank you very much Denis! Just by reading and understanding a few lines of your code, I learned a lot, I really appreciate it man. Thank you for your time, and for all the time you have saved me.
I'll post my final code below, in case it helps anyone else.
macroscript MyCustomTool_001
category:"MyTools"
tooltip:"UV Channel Projection"
	rollout projectMutipleUVsRollout	"UV Channel Projection"
		spinner sourceUV "Source UV Channel:" range:[1, 100, 2] type:#integer width:150 pos:[35,10]
		spinner targetUV "Target UV Channel:" range:[1, 100, 2] type:#integer width:150 pos:[35,35]
		button btnProjectUVs "Project UVs" width:150 height:30 pos:[25,70]
		on btnProjectUVs pressed do
			global val1 = sourceUV.value
			global val2 = targetUV.value
				local refList = #()
				local pMod = Projection ()
				--> go to modify mode
				max modify mode
				select obj
				modPanel.addModToSelection pMod
					-- Get the name of the possible target
					local targetName = target.name
					--Compare with the base name of the selected object
					if (findString targetName baseName) == 1 and (targetName != objName) do
						pMod.addObjectNode target
						append refList target
				pMod.addRegisteredProjectionType 1 -- works only if pmod is a current edit ModPanel object:
				if (pMap = pMod.getProjectionType 1) != undefined do
						pMap.sourceMapChannel = val1
						pMap.targetMapChannel = val2
						pMod.projectAll()
						for ref in refList do ( collapseStack ref )
						deleteModifier obj pMod
				--Call function
				add_projection_mod (selectedObjects)
			else
	createDialog projectMutipleUVsRollout 200 120
Message 9 of 9
denisT.MaxDoctor
By the way, this sentence is incorrect. The projection target list (if it is empty, for example) does not affect the definition of the projection-type object. As I said in the code, the problem is that MXS has no method to add a registered projection type to an "inactive" modifier. The modifier must be selected as the current edit object in the modifier panel to initialize its local data and make the projection-type object defined.
