proboolean
proboolean
proboolean
Hello
I have a big max file (20Km on 20 Km) that I want to cut into separated smaller pieces (5Km on 5Km)
I thought I could use the ProBoolean tool in a script but it doesn’t work at all
I have a few objects and I created a bounding box for that area
This is the full script:
newPos = $.pos
delete $
max select all
objNum = selection.count
theObjs = selection
clearSelection()
for i = 1 to 1 do (
mybox = box length:5000 width:5000 height:500
mybox.pos = newPos
print “Boolean”
ProBoolean.createBooleanObjects theObjs[i] mybox 1 1 1
convertTo theObjs[i] Editable_Poly
If you can help me with the script/give me a different idea that would be great
Thank you
drew_avis
I think you have the createBooleanObjects parameters reversed - the first is operand A, and the second is an array of nodes to use as operand B.  So this would work:
ProBoolean.createBooleanObjects  mybox theObjs 1 1 1
Hope that helps,
Drew
Drew Avis
Content Experience Designer
I changed it and it still didn't work.
Isn't there an option to do a simple boolean by script? (and not ProBoolean)
I can happily attach photos to make my problem and my need clearer
