Message 1 of 14
01:22 AM
- Mute
- Permalink
- Report
Hello @Anonymous,
Questions about VMMP are probably best directed toward Siger Studios tech support since we don't have access to the code for this plugin. However I have seen VSSP throw errors like this if Vray isn't the current renderer when you click the VSSP button. Maybe try making Vray your current renderer and click again. If that doesn't work I suggest sending a support request on this page. They are pretty good about getting back within 24 hours, and best of luck!
Please hit the "Accept as Solution" button if my post fully solves your issue or answers your question. This lets me know that I was effective in helping you, and thank you for doing so.
Best Regards,
Alfred (AJ) DeFlaminis
3ds Max Technical Support Specialist
Autodesk Here to Help | View Max Tips/Tricks | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Change Display Drivers in Max | Feature Request Board | Installation and Licensing Forum | 3ds Max Certified Hardware | Network Rendering Troubleshooting Guide
Hello @Anonymous and welcome to the community!
Make sure Vray is your current renderer before you click the VMMP icon, otherwise this question is best asked to Siger Studio since they developed the plugin.
Best Regards,
I can't do much support on 3rd party programs. I'm guessing that the problem is with Windows interacting with the plugin. My best suggestion is to try the following:
1) Try to update .Net from 4.5.1 to 4.5.2
2) Try logging into your PC as a different user to see if your user profile is corrupted
3) Try reinstalling your Visual C++ runtimes. You can do that easily using the all-in-one installer tool at the bottom of this article from MajorGeeks.
Beyond that I'm out of ideas. Please try those things.
Best Regards,
@Anonymous wrote:Siger Studio Not Solving Problem
This issue occurs when you use decompiled/cracked and badly recompiled plugin 🙂 The official release is free from such problems.
Hello @Siger_ and welcome to the community,
Thank you very much for the information. I have unmarked the solution and will mark your post as the solution. It saddens me to read it though. As a long time customer of yours, I salute you for your amazing plugins. Thank you for making the field that much easier to work in.
Best Regards,
i got this issue can any body help me please
siger studio vray material preset pro
when the window appears, select ok and reopen the script, it will work and do not close it after.
This is not a solution !
The problem here is due to Visual Studio lack of smart coders !
Just update your OS and run both programs as Admin, after a virus check, of course.
Enjoy!
