Problem with very simple script
AgustinLanus
Message 1 of 8
AgustinLanus
So I'm making this very simple UVW script which just applies a box UVW map with an inputted value, here it is in all of it's glory:
v = getKBValue prompt:"Enter object count:"
modPanel.addModToSelection (Uvwmap ())
$.modifiers[#UVW_Map].maptype = 4
$.modifiers[#UVW_Map].length = v
$.modifiers[#UVW_Map].width = v
$.modifiers[#UVW_Map].height = v
This works just fine from the script editor but when I make it a macro script so I can set a hotkey to it I can only use it once and then I get this error:
Does anyone know what may be happening?
Replies (7)
Message 2 of 8
AgustinLanus
Also if I try to run it with a hotkey on more than one object at the same time I get this error every time:
Which also doesn't appear when I run it from the script editor
Message 3 of 8
denisT.MaxDoctor
In MXS, a single $ signifies the current selection. In the case where only one node is currently selected, it returns the actual node, but in the case of multiple selection, it returns a set of objects, which in general cannot provide access to the node's parameters (e.g. #modifiers in your particular case).
Therefore, it is the good practice to never use the $ character in max scripts, but only use it for quick and dirty typing in the Listener.
Instead of using $ use selection[1], which is always the first node selected, or undefined if nothing is selected.
The  code in your case might look as:
	if isvalidnode (n = selection[1]) do
		m = n.modifiers[#UVW_Map]
		if m != undefined do
			m.maptype = 4
			m.length = m.width = m.height = v
Message 4 of 8
denisT.MaxDoctor
If you want to add one (the same) instance of the UVW Map modifier to a multiple selection, the correct way to do it is:
	m = UVWMap maptype:4 length:v width:v height:v
	modPanel.addModToSelection m
	-- or
	addmodifier selection m
Message 5 of 8
AgustinLanus
That certainly looks a lot cleaner!
I'm probably missing something really basic as I barely understand maxscript yet but should I be getting "undefined" when I run that code as it is?
I just added v = getKBValue prompt:"Enter object count:" at the top to input the value
Message 6 of 8
AgustinLanus
Yes! this does the trick to add the modifier to any amount of objects, so that's one down but for some reason I still get get errors when I run it with a hotkey every other use.
What's the correct way to make a script go from the script editor into a hotkey? I use the macroScriptCreator script to turn them into macroscripts which I can then easily access but that seems to be breaking something here.
Message 7 of 8
denisT.MaxDoctor
I would do something more intuitive and visually more accessible ... Something like:
	result = false
	if selection.count > 0 do
		rollout type_a_number_Rollout "UVW size:" width:134
			local value
			edittext text_input width:130 pos:[0,5]
			on text_input entered text do
				v = try(text as float) catch()
				if isnumber v then
					value = v
					destroydialog type_a_number_Rollout
				else
					text_input.text = ""
					setfocus text_input
			on type_a_number_Rollout open do setfocus text_input
		createdialog type_a_number_Rollout modal:on
		if isnumber (v = type_a_number_Rollout.value) do undo "Add UVW Modifier" on
			uvw_mod = uvwmap width:v length:v height:v
			addmodifier selection  uvw_mod
			result = true
	format (if result then "SUCCEEDED!\n" else "FAILED!\n")
	result
Message 8 of 8
AgustinLanus
I love the idea of having that messagebox appear for the input but sadly for some reason that code isn't compiling for me, after typing a number and pressing enter I just get errors.
