pre Multiplied Alpha script
I'm currently writing a script to identify if any objects in the scene with a standard material that has a diffuse (or opacity map) that have the preMultAlpha switched set to on and if so report it (so I know what material was changed) and then switch it off. Simple enough, only I can't seem to set the switches for preMultAlpha to off and I can't get the opacity map part to work either. (Which is most of the script actually...ahem) Can anyone please help me out. Thank you.
PiXeL_MoNKeY
This will disable the preMultAlpha switch for all bitmaps in the scene:
for preMult in (getClassInstances BitmapTexture) do (
preMult.preMultAlpha = false
Personally I wouldn't dig through the materials, I would use what I did and change the BitMapTexture Objects. Without seeing your code (and possibly a sample scene) it is going to be hard to pinpoint what the problem is.
-Eric
Thank you PiXeL_MoNKeY, I see the reason why I was going wrong now:
if dif_map.preMultAlpha == true do dif_map.preMultAlpha = false
Steve_Curley
$.material.diffuseMap.preMultAlpha
$.material.opacityMap.preMultAlpha
Look up "StandardMaterial - Material" in the Maxscript Help Index.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
Steve_Curley
Eric beat me to it again 😞
Max 2016 (SP1/EXT1)
PiXeL_MoNKeY
Just don't hold it against me Steve. 😉
-Eric
Steve_Curley
As if I'd do a thing like that 😛
Max 2016 (SP1/EXT1)
