Populating pop up window button with .mat file content
contactZZUHX
contactZZUHX
I'm trying to create a pop up window with buttons that will be populated with the name of an extracted .mat file that contains different materials. The idea is to use this pop up window as a quick way to apply textures within the viewport without going back to the SME by directly loading my standard .mat library that I use for all my projects.
Anyway, I keep getting some basic syntax error and I can't for the life of me find where the thing is going wrong. The script is not complete yet (as in I'll need to add a few things for it to do exactly what I need), but it's already breaking at the current step.
Below is the code :
try (destroyDialog materialButtonsDialog) catch()
rollout materialButtonsDialog "Material Library" width:350 height:640
    local buttons = #()
    -- Function to create buttons dynamically based on material names
    fn createButtons materialNames =
        local posX = 10
        local posY = 30
        local buttonWidth = 320
        local buttonHeight = 25
        local margin = 5
        for i = 1 to materialNames.count do
            local btnName = "btn_" + i as string
            local btn = button btnName text:materialNames[i] pos:[posX, posY] width:buttonWidth height:buttonHeight
            posY += buttonHeight + margin  -- Increment position for the next button
            append buttons btn  -- Add button to the array
            -- Add a simple event to demonstrate functionality
            on btn pressed do
                messageBox ("Material selected: " + btn.text)
    -- Function to load materials from a .mat file and return their names
    fn loadMaterialNamesFromMatFile =
        local filename = getOpenFileName caption:"Select Material Library" types:"Material Library (*.mat)|*.mat"
        local materialNames = #()
        if filename != undefined then
            local myLibrary = loadTempMaterialLibrary filename
            if classOf myLibrary == MaterialLibrary then
                for mat in myLibrary do
                    if mat != undefined then
                        append materialNames mat.name
            else
                messageBox "Failed to load the selected .mat file as a Material Library."
        else
            messageBox "No file was selected. Please select a valid .mat file."
        return materialNames
    -- Event to load materials and create buttons when the rollout opens
    on materialButtonsDialog open do
        local materialNames = loadMaterialNamesFromMatFile()
        if materialNames.count > 0 then
        else
            messageBox "No materials found in the selected .mat file."
    button btnClose "Close" pos:[10, 610] width:330 height:25
    on btnClose pressed do
createDialog materialButtonsDialog 350 640 resizable:false
If anybody has any idea on how to fix it, or do it differently, that would be greatly appreciated!
Simon
contactZZUHX
Ok, after some fiddling and further research I managed to make it work. I'll put it here in case people are interested in the concept :
global myLibrary
-- Prompt the user to select a .mat file
filename = getOpenFileName caption:"Select Material Library" types:"Material Library (*.mat)|*.mat" initialDir:""
-- Check if a file was selected
    -- Attempt to load the material library
    -- Check if the library loaded successfully
        -- Generate the rollout definition as a string
        rolloutDef = "rollout dynamicRollout \"Material Buttons\" width:440 height:640\n"
        rolloutDef += "(\n"
        rolloutDef += "    local hiddenObjects = #()\n"
        rolloutDef += "    checkbox chkHideAfterRename \"Hide after rename\" pos:[10,10] width:190 height:20\n"
        rolloutDef += "    button closeBtn \"Close\" pos:[230,10] width:190 height:30\n"
        -- Add buttons for each material
        local btnPosY = 50
        for i = 1 to myLibrary.count do
            local mat = myLibrary[i]
                local btnName = "btn" + i as string
                rolloutDef += "    button " + btnName + " \"" + mat.name + "\" pos:[10," + btnPosY as string + "] width:420 height:25\n"
                btnPosY += 30
        -- Add function definitions and event handlers
        rolloutDef += "    fn renameAndHideObjects newName matIndex = (\n"
        rolloutDef += "        if selection.count > 0 then (\n"
        rolloutDef += "            for obj in selection do (\n"
        rolloutDef += "                obj.name = newName\n"
        rolloutDef += "                obj.material = ::myLibrary[matIndex]\n"
        rolloutDef += "                if chkHideAfterRename.state then (\n"
        rolloutDef += "                    append hiddenObjects obj\n"
        rolloutDef += "                    obj.isHidden = true\n"
        rolloutDef += "                )\n"
        -- Add button event handlers
                rolloutDef += "    on " + btnName + " pressed do renameAndHideObjects \"" + mat.name + "\" " + i as string + "\n"
        -- Add close button event handler
        rolloutDef += "    on closeBtn pressed do (\n"
        rolloutDef += "        for obj in hiddenObjects do obj.isHidden = false\n"
        rolloutDef += "        destroyDialog dynamicRollout\n"
        rolloutDef += ")\n"
        -- Execute the rollout definition
        execute rolloutDef
        -- Create and show the dialog
        createDialog dynamicRollout
    else
        messageBox "Failed to load material library. Please ensure you selected a valid .mat file."
else
    messageBox "No file selected."
denisT.MaxDoctor
you can use rolloutcreator and subrollout control instead:
try(destroydialog rol) catch ()
rollout rol "RO:183453F0" width:191 height:300
	subrollout sub_rol width:180 height:280
	fn makeMatButtons lib =
		rollout_name = #LibMaterialsRollout
		rcg = rolloutCreator rollout_name "Lib Materials" width:140
		rcg.begin()
		for k=1 to lib.count do
			mat = lib[k]
			name = "mat_bt" + (k as string)
			rcg.addControl #button name mat.name paramstr:("align:#center width:120")
			rcg.addHandler name #pressed \
				codeStr:("(format \">> %\\n\"" + name + ".text" + ")")
		rcg.end()
		rcg.def
	on rol open do
		lib = meditmaterials
		mrol = makeMatButtons lib
		addsubrollout sub_rol mrol autoLayoutOnResize:on
createdialog rol
contactZZUHX
I'll give it a go. Thanks!
