pngio.setType
pngio.setType
pngio.setType
Hi
i am using maxscript and the rendermap functionality to bake down procedural material graphs.
I noticed that my bitmap were saved out as 16bit png. The original material graph also had 16 bit bitmaps.
I found on the net the pngio.SetType command and issued in code a
pngio.setType #true24
After that all png files are saved as 8 bit. Even if i remove the above line form the the code or restart edsmax
How does the pngio command work? Is it permanent?
How do i reset to the default funtionality for png?
Dimi
RGhost77
setType <enum>type
enums: {#paletted|#true24|#true48|#gray8|#gray16}
Yes, it is permanent. You should change type by script or UI. So you need set type by  setType choosing that type what you need.
Royal Ghost | veda3d.com
