Announcements
Please help me about modifier in Maxscript.
mihi0315
mihi0315
I am creating a modifier to inset and then extrude, but only the extrusion is being executed.
Please help me understand what’s wrong.
plugin modifier Test
classID:#(0x3bc16b9f, 0x740a29ad)
extends:Edit_Poly
replaceUI:on
    parameters main rollout:params
        Gap type:#float default:1 ui:spnAmount
        on Gap set val do (
            delegate.setOperation #Inset
            delegate.insetType = 1
            delegate.insetAmount = val
            delegate.modifier.Commit()
            delegate.setOperation #ExtrudeFace
            delegate.extrudeFaceHeight  = val
    rollout params "Parameters"
        spinner spnAmount "Gap: " type:#WorldUnits range:  [0, 1e6, 1]
    on create do
        delegate.setEPolySelLevel #Face
regards!
denisT.MaxDoctor
I don't think more than one operation is allowed ... I think only one local data change is intended.
The only solution I see is to use two modifiers - #insert and #extrude.
mihi0315
Thank you for your reply.
It seems that only one operation is allowed.
I will try the solution!
denisT.MaxDoctor
look https://www.scriptspot.com/3ds-max/scripts/extrudeinsetoutline-faces-modifiers
Kudos to Swordslayer for showing a skillful way to extend the Edit_Poly modifier.
(Note. To those interested, the scripts were written five years ago, and using a Change Handler is no longer necessary in recent MAX versions.)
mihi0315
Thank you for the reference site.
I also used it as a reference.
I thought it would be easier to work if I could create a script that could perform multiple operations at the same time.
denisT.MaxDoctor
“Multi-operations” will work better. But this cannot be done by extending Edit_Poly.
Maybe there's a hack, but I don't see it yet.
