Announcements
Help!Max2025 and Qt6,when i want to get the name of a node,its output is garbled!
2829024262
2829024262
I am using the Max 2025 SDK with Qt 6 and VS 2019. I want to get the name of an INode* type and output it using qDebug(), but the output is always garbled. How can I solve this?
I am using GB2312 encoding in VS2019, and I want to display the name of an INode* on a Qt-made UI, but it is also showing as garbled text.
INode* node=ip->GetSelNode(0)->GetName();
qDebug() << QString::fromWCharArray(node->GetName());
MSTR name(node->GetName());
qDebug() << name.operator QString();
MSTR t = node->GetName();
std::wstring tt = t.data();
qDebug()<< QString::fromStdWString(tt);c
qDebug() << QString::fromUtf8(QString::fromWCharArray(node->GetName()).toUtf8());
The result of the above four output methods is(in vs console output window):
"䕨\u0A12翶"
"䕨\u0A12翶"
"䕨\u0A12翶"
"䕨\u0A12翶"
istan
Have you also tried this?
TSTR nam = node->GetName();
QString str = nam;
denisT.MaxDoctor
try:
MSTR name = node->GetName();
auto str = QString::fromWCharArray(name.data());
This is still wrong.😭
auto str = QString::fromWCharArray(t.data());
qDebug() << str;
"䕨䕆翶"
When I'm on the other version 2017-2024,How I use it is:qDebug() <<QString::fromWCharArray(node->GetName());.
I can print the name of node in the scene correctly, but I don't know why 2025 doesn't display correctly.
Yes, I tried.But it hints that there is no proper constructor to convert from const wchar_t* to CStr.
I've found a solution,I added a macro "#define __T(x) L ## x" to the docs tchar.h.
