Announcements
particle flow
particle flow
MichaelInneer
particle flow
MichaelInneer
When using script 3ds max works 10 times slower than using path follow? Sometimes particles just jump from 1st frame to the last. It happens when i enable script. Nothing is edited. What can be the problem? (CPU i5-10400 so i doubt it's slow)
omidt_gh
there are many possibilities, first, I need to see what's inside your script to see if you have a loophole inside it.
if you just want to prevent the jumping on time slider go to time slider settings and disable real-time playback.
That's not a solution to slow script but it'll fix the problem with playback in the viewport.
MichaelInneer
You're right that's not. But still thanks. As for script it's standard when you activate script in PF Source Panel.
