Object transform parameters does not rounding
mahmutoymaci
mahmutoymaci
Hi. I am trying to understand why the matrix values ​​of the green object in the video are not rounded. Please do not ask why I want to understand this. What could be wrong with this object? I want to do this without deleting and recreating the object. If you want to try it yourself, you can download the file.
leeminardi
Keep in mind that Max uses a single precision floating point database.  Coordinates have a mantissa of 23 bits or 1 part in 2^23 (8,388,608). This yields a precision a little better than 6 significant figures.  The value you see of -1.42261e-06 is at the limit of Max's precision.  You can consider it to be 0.0 for Max applications.
BTW,  the follwing message appeared when I opened your drawing.
lee.minardi
mahmutoymaci
You misunderstood the problem.
