Object Oriented Programing: Include a rollout as a member?
Try this one:
struct trafficLine
name = "the name of the type",
info = "some describ",
image = "a preview image path",
width = 0.15,
length = 4.0,
spacing = 2.0,
guideLine = #(),
Poly = #(),
fn makePoly =
if isValidNode poly and poly != undefined do delete poly
tempPart = plane width:width length:length
Poly = MakeStripPoly guideLine tempPart spacing 0.5 off --To make the test work, this line may be replaced by "poly = plane( )".
delete TempPart
poly
fn resetGuideline =
guideLine = undefined
fn resetPoly =
poly = undefined
panel = rollout panel name
button apply "apply"
on apply pressed do makePoly()
fn makePanel =
try destroyDialog panel catch()
createdialog panel
a = trafficLine ()
a.guideline = circle()
a.makePanel()
well, it's all fine till you press the botton "apply".
I"m trying to make the UI defination as part of the object, is that possible?
(In fact, I've already solved this case in another way: I create a rollout outside the struct defination and a initiallizePanel( ) inside.)
Did you try passing in the instance of a trafficLine to the makePanel function? The following 'create, then initialize' worked for me
struct trafficLine
-- <same original stuff>
local makePolyFn = undefined
on apply pressed do if (classof makePolyFn == MAXscriptFunction) then makePolyFn()
fn makePanel owner =
try destroyDialog owner.panel catch()
createdialog panel
panel.makePolyFn = owner.makePoly -- initialize the panel
a = trafficLine()
a.makePanel(a) -- Pass in the owner, sorta like a 'this" argument...
Nice! I hadn't tried assigning it to a member. Thanks for that.
