OBJ Import Flip ZY-axis
I try to import OBJ file in maxscript:  importFile myFile.obj #noPrompt
How can I disable flipping ZY-axis. In Import dialog there is check-box "Flip ZY-axis". But I want to disable this option programmatically (in script).
Thanks in advance.
blakestone
I am not sure if this option is exposed in maxscript.
You could do this via script after the object has been imported:
max select all -- select all objects
rotate selection 90 [0,1,0] -- rotate selection 90 degrees 'Y-Axis'
resetXForm selection -- reset xform (pivot)
collapseStack selection -- collapse stack / modifier list
denisT.MaxDoctor
setinisetting (objimp.getIniName()) #geometry "FlipZyAxis" "0"
