noob question: loop not working - eof error when reading a txt file
Message 1 of 11
I am trying to write a script that will read in two component codes from each line of a text file and edit the corresponding components.
The code works for the first line of the text file and edits the components correctly(whithout the loop). However when i tried to get it to loop through the rest of the lines in the file it fails and i get end of file errors.
I cant seem to find a loop that works properly
here is the code i am working on:
global fileUnderTest = "c:\\test1.txt"
--fn overlapHighlight dirString=
max select all
$.xray = on
--fileUnderTest = dirString
fs = openFile fileUnderTest
seek fs #eof -- couldnt get a while loop to work so i tried this instead
maxlen=filepos fs
seek fs 0
count = 1
while count != maxlen do (
count = filepos fs
skipToString fs "Component "
obj1 = readChars fs 6
obj2 = readChars fs 6
myObj1 = getNodeByName obj1
myObj1.xray = False
myObj2 = getNodeByName obj2
myObj2.xray = False
selectionSets = #(myObj1, myObj2)
close fs
This is a sample from the text file i am trying to read
!! Component ab1001 OVERLAPS Component ab1002 !!
!! Component ab1003 OVERLAPS Component ab1004 !!
!! Component ab1001 OVERLAPS Component ab1001 !!
!! Component ab1001 OVERLAPS Component ab1004 !!
!! Component ab1007 OVERLAPS Component ab1007 !!
Replies (10)
Message 2 of 11
Steve_Curley
fn overlapHighlight inFileName =
local theFile, myObjects = #()
geometry.xray = True
theFile = openFile infileName
while not eof theFile do
skipToString thefile "Component "
myObjects = getNodeByName (readDelimitedString thefile " ")
myObjects.xray = False
selectionSets.name + "--" + myObjects.name] = myObjects
skipToNextLine theFile
close theFile
overLapHighlight "c:\\test1.txt"
Looks better with proper indentation (forum problem...) - actual script is attached.
overlappingobjects.ms.zip
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
Message 3 of 11
Hi mate,
Thanks for that,
But for some reason the myObjects is not getting populated
it contains (undefined, undefined) which causes the .xray command to fail etc
any clue why?
i am using max 2009 attached is the text file and a test max file (this might help?)
Message 4 of 11
Steve_Curley
Attachments (other than images) must be zipped first.
I did, obviously, test it here before I posted it. If the myObjects are not being populated then either
a) there are no objects in the scene with the same names as are in the file, or
b) the format of the file is different to your example a few posts up and you didn't alter the code to suit, or
c) you did change the code to suit a different file format. The spaces after the "Components " are necessary, not accidental, for example.
Try attaching the scene and text file again - zip them both together - because it will be a lot easier to diagnose the problem in situ.
Max 2016 (SP1/EXT1)
Message 5 of 11
Sorry about that,
Didin realise they had to be zipped up
It is strange, its the same problem i was having before, if i remark out the while loop the code works fine for the first line of the txt file, however with the loop it falls over and the array will not populate
your help is much appreciated!
desktop.zip
Message 6 of 11
Steve_Curley
The object names in the max scene have spaces in them - "tk 1001" - but in the file they do not - "tk1001". In this instance it will be easier to change the names in the scene rather than the file, because reading the split names will be more difficult. Or you could put underscores in both, but no spaces.
Also, the last line of the text file does not have a CRLF (0x0D 0x0A) - this will cause problems reading that last line.
Max 2016 (SP1/EXT1)
Message 7 of 11
One of the objects in the txt file was not in the scene tk0007
however
It still appears to be a read past end of file error caused by the "skipToNextLine theFile" line
if you remove this you get the following
it populates the array - however for some reason the last two values in the array are undefined- this appears to be where it is now falling over
$Box:tk1001 @
$Box:tk1002 @
$Box:tk1003 @
$Box:tk1004 @
$Box:tk1001 @
$Box:tk1001 @
$Box:tk1001 @
$Box:tk1004 @
$Box:tk1001 @
$Box:tk1002 @
$Box:tk1003 @
$Box:tk1004 @
$Box:tk1001 @
$Box:tk1001 @
$Box:tk1007 @
$Box:tk1007 @
undefined
undefined
Arrrrg!
Message 8 of 11
Hi i just saw your reply
The Object names in the max file are identical to the ones in the txt file, there are no spaces??
they are tk1001 tk1002 etc
There should be a carrage return at the end of the file, sorry that was my error.
It doesnt seem to make any difference though... can you get it to work?
Message 9 of 11
Steve_Curley
Ok, forget the spaces - old eyes playing tricks on me :(
Right. Load the scene, change "tk1008" to "tk1007".
Open the text file with notepad, move the cursor to the end of the last line, press Enter and then save the file. Then it all works as expected.
The file error is being caused by the missing CRLF.
If you need to do this job repeatedly, then it would pay to put some error trapping in to handle the various possible errors.
The file wouldn't open
The object(s) don't exist in the scene
The end of file was reached unexpectedly
etc.
Max 2016 (SP1/EXT1)
Message 10 of 11
yup,
Hats off to you,
I had a break came back to the pc and have been playing around with the different .txt encoding methods to try and get it to work
you were right It was the missing return at the end of the file. I was sure i had tried that before.
The annoying thing is that the file will be generated with a carrage return on it from a unix script.
Thanks for all your help man, this part was only supposed to take me 10 mins its part of a much bigger CAD project. LOL
Message 11 of 11
Steve_Curley
No problem - glad we got it sorted :)
Max 2016 (SP1/EXT1)
