.net control WebBrowser, need help with something
I'm attempting to integrate a System.Windows.forms.WebBrowser control into a script that will allow for data entry and I'm having a problem where the Enter and Tab keys don't do anything.
I've just started to delve into .net controls within Maxscript and I'm thoroughly confused as to what I might be missing here. I've simply copied and pasted the example code provided in the Max help docs (sorry for removing the K&R bracketting Bobo) and have included a website with a Rich Text editor for testing. If you simply copy/paste and evaluate the following code you'll find that a website loads with a multi-line text control, you can type into the box with no problems, however, the Enter key and Tab do absolutely nothing, does anyone have any ideas?
-Jon
rollout webbrowser_rollout "Web Test" width:600 height:600
edittext edt_url "URL:" text:"http://www.kevinroth.com/rte/demo.php"
dotNetControl wb "System.Windows.forms.WebBrowser" pos: width:580 height:570
fn openURL urlString =
wb.url = dotNetObject "System.Uri" urlString
on edt_url entered txt do openURL txt
on webbrowser_rollout open do openURL edt_url.text
createdialog webbrowser_rollout
If you are under Max 2008 or higher you should try to use a MaxForm:
-- Load MaxCustomControls assembly
-- This assembly contains UI components built on the .NET Framework for use in 3ds Max
dotNet.loadAssembly "MaxCustomControls.dll"
-- Create WebBrowser
webBrowser = dotNetObject "System.Windows.forms.WebBrowser"
webBrowser.Location = dotNetObject "System.Drawing.Point" 10 10
webBrowser.Width = 570
webBrowser.Height = 540
webBrowser.Url = dotNetObject "System.Uri" "http://www.kevinroth.com/rte/demo.php"
-- Create Max Form
maxForm = dotNetObject "MaxCustomControls.MaxForm"
maxForm.Size = dotNetObject "System.Drawing.Size" 600 600
maxForm.Text = "Max Form with WebBrowser"
maxForm.Controls.Add(webBrowser)
maxForm.TopMost = true
FormBorderStyle = dotNetClass "System.Windows.Forms.FormBorderStyle"
maxForm.FormBorderStyle = FormBorderStyle.FixedDialog
maxForm.ShowInTaskbar = false
maxForm.MinimizeBox = false
maxForm.MaximizeBox = false
-- Show MaxForm
maxForm.ShowModeless()
Thank you very much for the reply and the sample code Yannick. I didn't realize there was a custom MaxForm for such a purpose. I just searched the MaxScript documentation and couldn't find any reference to it, is there any source for information on this?
Thanks again,
Jon Adkins
It's only documented in the SDK Reference (3ds Max .NET SDK). In fact there are others controls and utils in these assemblies. This .NET SDK was created for use in plugins but MaxForm is very useful in MAXScript.
Awesome, thanks again.
