Nesting string data in string stream
bertv
Message 1 of 13
bertv
Hey,
I was wondering how one can nest a string in a string?
Example this:
Box name:"test" width:10 height:20
How to  put it in a stringed format as seen below to run with the execute command:
"Box name:"test" width:10 height:20"
I tried the following,
main_ss = stringstream ""
format "Box name:% width:10 height:20" "test" to:main_ss
execute(main_ss as string)
free main_ss
But got the following error
-- Error occurred in anonymous codeblock; filename: ; position: 19; line: 1
-- Unable to convert: undefined to type: String
-- MAXScript callstack:
-- thread data: threadID:26704
Replies (12)
Message 2 of 13
bertv
Found it by change 🙂
Parentally you can add \" in the string
format "Box name:\"%\" width:10 height:20" ("test" as string) to:main_ss
free main_ss
Message 3 of 13
bertv
I wanted to know if you can even go deeper in nesting the string with the stringstream?
Message 4 of 13
denisT.MaxDoctor
	name_ss = stringstream ""
	wcol_ss = stringstream ""
	format "Sample_%" (timestamp()) to:name_ss
	format "(color % % %)" 255 128 128 to:wcol_ss
	exec_ss = stringstream ""
	str = "box name:\"%\" wirecolor:%"
	format str (name_ss as string) (wcol_ss as string) to:exec_ss
	execute (exec_ss as string)
	free #(name_ss, wcol_ss, exec_ss)
Message 5 of 13
bertv
Hi again Denis 😉
The problem is I'm trying to combine the following code from a for loop to one string and execute it once. To booste performance by only calling Execute once with the concatenated string.
Code below is part of a for loop:
nameSwatch = "swatch_" + (counter as string)
nameBmp = "bmp_" + (counter as string)
element_ss = stringstream ""
format "rci.addText \"local % = bitmap % % color:%\"" nameBmp swatch_width swatch_height (col_line[2] as point3) to:element_ss
execute(element_ss as string)z
free element_ss
param_ss = stringstream ""
format "bitmap:% tooltip:\"%\" iconSize:[%,%] pos:[%,%]" \
nameBmp col_line[1] swatch_width swatch_height swatch_x swatch_y to:param_ss
rci.addControl #imgTag nameSwatch "" paramstr:param_ss as string
rci.addHandler nameSwatch #click \
codeStr:("RoFn.processSelected @" + col_line[1] as string +"-" + col_line[2] as string + "-" + col_line[3] as string + "@") filter:on
free param_ss
I tried the code below but there are issues with the paramStr and codeStr. Because they are 2 levels deep nested in the string and there is a problem with the string literal indication. I tried to apply your suggestion but got stuck.
format "bitmap:% tooltip:\"%\" iconSize:[%,%] pos:[%,%]" nameBmp col_line[1] swatch_width swatch_height swatch_x swatch_y to:param_ss
ui_ss_01 = stringstream ""
format "rci.addControl #imgTag % \"\" paramstr:\"%\"" nameSwatch (param_ss as string) to:ui_ss_01
ui_ss_02 = stringstream ""
format "rci.addHandler % #click codeStr:(\"RoFn.processSelected @\" +  % +\"-\" + % + \"-\" +  % + \"@\") filter:on" nameSwatch col_line[1] col_line[2] col_line[3] to:ui_ss_02
--Final execute string
format "% \n % \n % \n" (element_ss as string) (ui_ss_01 as string) (ui_ss_02 as string) to:main_ss
The output is as follow:
This is one part from the 1500 outputs in the concatenated string =>
rci.addText "local bmp_21 = bitmap 44 20 color:[47,23,26]"
 rci.addControl #imgTag swatch_21 "" paramstr:"StringStream:"bitmap:bmp_21 tooltip:"RAL 010 40 15	" iconSize:[44,20] pos:[0,60]""
 rci.addHandler swatch_21 #click codeStr:("RoFn.processSelected @" +  RAL 010 40 15	 +"-" + [47,23,26] + "-" +  [118,85,91] + "@") filter:on
As you can see there is a string indication problem at the paramStr and codeStr
Message 6 of 13
denisT.MaxDoctor
do you want to dynamically create a UI with 1500 controls of the same type?
Message 7 of 13
bertv
Yes,
I'm creating a tool to pick certain colors.
At the moment all works well. But it just take about 5sec to load everything.
I think it's because of the Execute command called with the creation of each color slot.
That's why I try to combine all color slot creation in one large string and only call it once with execute.
Below a grab of the program:
Message 8 of 13
denisT.MaxDoctor
rol =
	bt_size = [24,22]
	bitmap_str = @"local col_% = %"
	params_str = @"bitmap:(bitmap 1 1 color:col_%) width:% height:% pos:%"
	handle_str =
		c = colorPickerDlg col_% %
		if c != undefined do
			col_% = c
			bm_%.bitmap = bitmap 1 1 color:col_%
	fn makeId index = (formattedprint index format:"04d")
	fn addInitColor id col =
		format bitmap_str id col to:ss
		str = ss as string
		free ss
		rcg.addText str
	fn addImageTag id pos width:bt_size.x height:bt_size.y =
		format params_str id width height pos to:ss
		str = ss as string
		free ss
		rcg.addControl #imgtag ("bm_" + id) "" paramstr:(str)
	fn addHandler id =
		format handle_str id "\"Extended Picker\"" id id id to:ss
		str = ss as string
		free ss
		rcg.addHandler ("bm_" + id) #click codeStr:(str)
	seed 1
	num_rows = 10
	num_cols = 8
	offset = [10,10]
	spacing = [4,4]
	rollout_name = "ExtendedColorPicker"
	w = num_cols * (bt_size.x + spacing.x) + offset.x * 2 - spacing.x
	h = num_rows * (bt_size.y + spacing.y) + offset.y * 2 - spacing.y
	rcg = rolloutCreator rollout_name "Extended Picker" width:w height:h
	rcg.begin()
	for y = 0 to num_rows - 1 do
		for x = 0 to num_cols - 1 do
			col = random black white
			index = y * num_cols + x
			pos = [offset.x + x * (bt_size.x + spacing.x), offset.y + y * (bt_size.y + spacing.y)]
			id = makeId index
			addInitColor id col
			addImageTag id pos
			addHandler id
	rcg.end()
	rol = rcg.def
createdialog rol
here is the way how it can be done.
Message 9 of 13
bertv
Hi Denis,
Thanks for the help.
Tested the code. It works, but also takes some seconds before showing the tiles when bumping up the row count.
Not sure if this can be optimized to work faster.
Bert
Message 10 of 13
denisT.MaxDoctor
you should use .NET or Qt ... MaxScript is not for heavy UIs
Message 11 of 13
bertv
Ok, thanks Denis
Learned a lot.
I'll have a look at .NET to update my code
Message 12 of 13
denisT.MaxDoctor
Why do you need to make 1500 buttons in your case? Make one bitmap for all colors at once and use it with one imgTag control... imgTag click (press/release) handle gives the click position.
One control - one handle... quick and easy.
try(destroydialog rol) catch()
rollout rol "RO:6D390B41" width:400
	local sub = rollout sub "COLORS"
		imgtag colors_ig style:#bmp_center width:380 height:1800 align:#center
	subRollout colors_sub width:390 height:800 align:#left offset:[-8,0]
	fn fillColors =
		bmp_master = bitmap 380 1800 color:(color 1 1 1)
		for y = 0 to 99 do for x = 0 to 9 do
			tag = bitmap 38 18 color:(random black white)
			pasteBitmap tag bmp_master (box2 0 0 tag.width tag.height) [x*38, y*18]
		sub.colors_ig.bitmap = bmp_master
	on rol open do
		addSubRollout colors_sub sub
		fillColors()
createdialog rol
Message 13 of 13
denisT.MaxDoctor
here is more advanced:
rollout rol "RO:2ED44C08" width:400
		local dim = [10,100]
		local bmp_size = [380, 1800]
		local tag_size = bmp_size / dim
		imgtag colors_ig style:#bmp_center width:(bmp_size.x+2) height:(bmp_size.y+2) align:#center
		local colors = #()
		fn sort_by_magnitude c1 c2 =
			if (h = int ((c1.h - c2.h) / 8)) == 0 then
				--c1.v - c2.v
				length (c1 as point3) - length (c2 as point3)
			else h
		fn fillColors =
			colors = #()
			for y = 0 to dim.y - 1 do for x = 0 to dim.x - 1 do
				append colors col
			qsort colors sort_by_magnitude
			bmp_master = bitmap bmp_size.x bmp_size.y color:(color 1 1 1)
				index = y * dim.x + x + 1
				col = colors[index]
				tag = bitmap tag_size.x tag_size.y color:col
				pasteBitmap tag bmp_master (box2 0 0 tag.width tag.height) ([x, y]* tag_size)
		on colors_ig lbuttondown pos flags do
			coord = [int (pos.x / tag_size.x), int (pos.y / tag_size.y)]
			index = coord.y * dim.x + coord.x + 1
			col = colors[index]
			format "pos:% coord:% index:% color:%\n" pos coord index col
			if (bit.and flags 0x8) do
				-- if CTRL:
		on colors_ig rbuttondown pos flags do
			col = colors[index]
			c = colorpickerdlg col "Pick A Color"
				bmp_master = colors_ig.bitmap
				pasteBitmap tag bmp_master (box2 0 0 tag.width tag.height) (coord * tag_size)
				colors[index] = c
	subRollout colors_sub width:390 height:800 align:#left offset:[-8,30]
	on rol open do
		sub.fillColors()
createdialog rol
