Need to reset Max to see some erros
alexandre_bisewski
alexandre_bisewski
Hey guys!
While I am building an script in MaxScript, sometimes When I restart Nax and open the script again I receive some errors. And when I run my script in the second time I dont receive this erros anymore.
So I usually restart my Max so see if everything is ok. But it is boring and take time.
Are there a better solution to do it? One function to maybe clear memory?
Thank you
denisT.MaxDoctor
Are there a better solution to do it? ...
The best solution is to fix the script. To do this, find a way to reproduce the error the first time you run the script manually.
Another good idea is to make the MAX reloading process more enjoyable: put music on in the background, play a slideshow, and maybe add some particle effects...
alexandre_bisewski
Hi Denis.
So when I run the script (ctrl+e) sometimes to see the update I need to to do it two times. Sometimes it doesnt happen.
So it maybe is an indicative that have something wrong in code?
denisT.MaxDoctor
If something goes wrong, there should be error messages and/or an output in the Listener. Show this output and error messages...
