Moving mirror in symmetry modifier
Hi
I want to create a macro that will align a box to a bone, add symmetry modifier to the box and make the mirror set itself to 0 in the X axis to get a referrence point on the other side of the X axis. But i don't understand how to move the mirror on the X axis to set it on 0.
Any help is welcome
denisT.MaxDoctor
@Anonymous wrote:
... add symmetry modifier to the box and make the mirror set itself to 0 in the X axis to get a referrence point on the other side of the X axis. But i don't understand how to move the mirror on the X axis to set it on 0.
everything sounds very simple and is clearly explained in the MXS help -> Symmetry : modifier
<symmetry>.axis Integer default: 0 -- integer, Specify the symmetry axis:
0 - X Axis
1 - Y Axis
2 - Z Axis
<symmetry.mirror>.position Point3 default: [0,0,0] -- animatable, The position of the Mirror gizmo.
But I think you are asking something else ... maybe a simple picture will help
And this is what i have that works for now
$[1].pos = $[2].pos
SymmetryCube = Symmetry()
select $[1]
modPanel.addModToSelection (symmetry ()) ui:on
$.modifiers[#Symmetry].PlanarZ = off
$.modifiers[#Symmetry].PlanarY = off
$.modifiers[#Symmetry].PlanarX = on
$.modifiers[#Symmetry].slice = 0
$.modifiers[#Symmetry].weld = 0
subobjectLevel = 1
--- Need the mirror to move in X axis here, from any position in the world
Sorry for the delay, i was sure i gave you this answer 
