Does LibShutdown actually get called on .dlx mxs plugins ?
klvnk
klvnk
Or do they use another naming convention  as with LibInit with dlx and not LibInitialize as with all other types of plugins ?
denisT.MaxDoctor
not sure if this helps you, but I look into some of my DLXs and see that the LibShutdown () is commented there. It should have made sense or a reason ... And in one of my DLXs I use NOTIFY_SYSTEM_SHUTDOWN to complete all remaining issues. Probably it was the only working solution.
istan
@denisT.MaxDoctor wrote:
... And in one of my DLXs I use NOTIFY_SYSTEM_SHUTDOWN ..
.. and I usually clean up and save my configuration stuff with the "file reset", "new file", "file load",.. notifications. I use shutdown only, if I need to disconnect from another server application.
klvnk
It's probably not a biggy as windows should clean up any "residuals"  and dlx's can't be unloaded like other plugins but it's the kind of thing that bugs me though.
