Moving faces via SDK
Hi everyone,
I'm dealing with SDK for the first time and have a problem. The goal is to change objects' thickness by moving its "bottom" faces via SDK. For example, there is a box and two its faces have material ID set to 100. I'm trying to select them by ID and move them:
pluginInstance->ip->MergeFromFile("D:\\test.max", true, false, true, false, NULL, 0, 0)
INode * pNode = SceneNodeByNameCache::GetInst().GetSceneNodeByName("Box001", true, false);
Object * obj = pNode->GetObjectRef();
if (obj->ClassID() == EPOLYOBJ_CLASS_ID)
PolyObject * po = (PolyObject *)obj;
EPoly * ep = (EPoly *)po->GetInterface(EPOLY_INTERFACE);
ep->SetEPolySelLevel(EP_SL_FACE);
ep->EpfnSelectByMat(100, FALSE, pluginInstance->ip->GetTime());
ep->MoveSelection(EP_SL_FACE, pluginInstance->ip->GetTime(), Matrix3(true), Matrix3(true), Point3(200,200,200), TRUE);
The code in "if" block is executed, doesn't give errors, but nothing happens. The box is loaded but not modified. What's the mistake?
Solved.
Notice that the material IDs in the Polygon MaterialIDs floater start from 1. But internally (for the SDK at least)these are zero based. Therefore a material ID of 100 in the rollout corresponds to 99 in code. Try changing 100 to 99 and watch the result. 😉
i.e.
ep->EpfnSelectByMat(99, FALSE, pluginInstance->ip->GetTime());
Btw in which header is SceneNodeByNameCache? It is certainly not in define_implementations.h. Had to use InterfacePtr->GetSelNode(0) to test the code.
I cannot avoid feeling that this is a very unhelpful forum. I am not a professional 3ds max developer (and even less a professional programmer), yet I am answering questions.
Thanks for your reply and help!
Solved.
SceneNodeByNameCache is located in pathname.h.
No problem. I myself could use some help now. How to adjust skin envelopes through the SDK?
What I am looking for is the equivalent of these MAXScript instructions.
skinOps.SetInnerRadius <Skin> \
<bone_integer> <CrossSectionID_integer> <Radius_float>
and
skinOps.SetOuterRadius <Skin> \
