Applying a bitmap image to a texture
Hi
I am using the following code in a SceneImport plugin.
BitMapTex* theTex= NewDefaultBitmapTex();
BitmapInfo bi;
Bitmap* bmap;
bi.SetName(longFileName);
bmap= TheManager->Load(&bi);
theTex->SetBitmapInfo(bi); //set Bitmap info first
theTex->SetBitmap(bmap);
Subsequently this texture is applied to a material. The appropriate bitmaps are initially visible on the scene materials in the material editor (as well as on the imported model when I use the "Standard display with maps" option on the menu), but the "view image" button in the material editor does nothing. And if I click "Reload" the texture disappears. It's obvious one or more extra function calls are missing; what could they be?
Btw I could have skipped creating a Bitmap and BitmapInfo and just used "SetMapName". Works fine at times but this occasionally causes crashes (probably because of invalid Bitmap* pointer).
hi, did you solve this problem? I am encountering the problem
ok,the problem is solved,
do not use setbitmap(), it is no use, u should use SetMapName(filePath);that's work, render in 3ds Max, you will see the bitmap
Thanks you for this topic. But I have problem with bitmap creating. TheManager->Load returns null, LoadInto has fail result. So I don't know. It should be so easy to create bitmap from png texture and set in to material. I working on it few days in row. But 3ds max API is the WORST API I ever seen.
Maybe you still have you code with this functional?
