Motion Capture Conversion Parameters dialog
Message 1 of 1
I would like to load, automatically, a batch of bvh files and I need to use footstep data .. So I don't want to display the motion capture conversation parameters dialog for each bvh file. The problem is that the footstep data is set by default to "none: Freeform" in the default setting of the motion capture conversation parameters dialog. So I have to load the first bvh file with #prompt option so that I can set the Footstep to "On", and then loading automatically the batch of bvh file..
As I want to avoid displaying the motion capture conversion parameters dialog, Is there any way to change the default setting so that the footstep will be set by default to "On" ?
Thank you in advance for your suggestions!
Nes
Replies (0)
